Viglent connect 10 bios dump
  • akarta
    • Nov 2015
    • 16
    Hi folks. I have a tabled pc in my hands with black screen after powering on. Owner told me that he was tinkering with bios settings before this happened.
    tablet is made by viglen ( Viglen connect 10 ) and it runs windows 10.
    Motherboard: EM_I8211_V6.2A (seems used on other tablets as well)
    SoC: Z3735G
    Bios rom chip: Winbond 25Q6FWS16 8MB
    tried flashing with bios found on this site with no luck
    http://**************/dump/prochie/elenberg_el_t1011_shassi_main_board_em_i8211_v6_2/300-1-0-37242
    Also there is eeprom chip on board, but I have no idea that it is for.
    If somebody has this tablet in your hand please share bios dump as I could not find any dumps on internet.
    I have included original and downloaded dumps if somebady needs it.
    regards
    Martynas
  • akarta
    • Nov 2015
    • 16
    Maybe there is a way to clear bios settings from original dump?And reflash it? I think it is AMI bios, but i'm not sure.
    • Habble7
      by Habble7
      Suspected Cause:
      Troubleshooting Attempts:
      05-22-2025, 07:28 AM
    • DynaxSC
      by DynaxSC
      11-17-2023, 10:56 AM
    • grimacelord
      Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
      by grimacelord
      This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
      Motherboard model number: DA0PAMB46A1 REV: A
      Secondary motherboard model number: 0PAB
      SKU: 685K4UA
      Serial number is: 5CD3223BJP
      Recently reflashed this laptop with latest BIOS and once...
      05-07-2024, 08:06 AM
    • DynaxSC
      Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
      by DynaxSC
      I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
      It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
      I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
      11-06-2022, 05:22 PM
    • TacticalFahrrad
      [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
      by TacticalFahrrad
      I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
      06-30-2025, 04:09 AM
