Please Need Help Dump Bios Asus S551LN-CJ406H
  • marino370
    • Feb 2017
    • 9
    • italia
    Hello friend , I need dump bios for notebook Asus S551LN-CJ406H , the notebook is dead and won't power on, power supply and motherboard seems ok.
    Thank you very much
  • angel-boy
    • 550
    Re: Please Need Help Dump Bios Asus S551LN-CJ406H
    Mainboard name and revision , graphic ic name, processor name, chipset name
    • marino370
      • Feb 2017
      • 9
      • italia
      Hi Angel-boy , this is all that I foud on mainboard and over the box:
      Asus S551LN-CJ406H - 60NB05F0-MBC060-221, VIDEO NVIDIA GeForce 840M VRAM:2GB , CPU INTEL I7 4510U/B0A RAM DDR31600
      Thank you
      • snsent
        • Nov 2010
        • 103
        • Malaysia
        see motherboard number on Motherboard..
        • marino370
          • Feb 2017
          • 9
          • italia
          Hi this is wrote on back of mainboard:
          PALWONN 88 M3 94V-0 E230435
          S551LN
          REV. 2.2
          • marino370
            • Feb 2017
            • 9
            • italia
            S551LN
            REV. 2.2
            • marino370
              • Feb 2017
              • 9
              • italia
              Hi , can you help me ?
              S551LN
              REV. 2.2
              thank you
              • razor_amd
                by razor_amd
                12-15-2020, 07:07 PM
              • DynaxSC
                by DynaxSC
                06-14-2024, 03:49 PM
              • jbonavita
                by jbonavita
                Some issues
                Things I tried
                04-29-2025, 09:38 PM
              • Habble7
                by Habble7
                Suspected Cause:
                Troubleshooting Attempts:
                05-22-2025, 07:28 AM
              • Anchar777
                ASUS P1412CE need BIOS DUMP
                by Anchar777
                Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
                06-26-2025, 03:39 AM
