Lenovo X1 Carbon Gen 2 (20A) Bios needed
  • ZFix
    • Nov 2020
    • Cyprus
    #41
    Re: Lenovo X1 Carbon Gen 2 (20A) Bios needed
    Hi, Can you please help me with this BIOS dump.
    The KB lights up one time and goes off, fan starts/stops, power on button and function buttons light is on, no POST, black screen.
    Type 20A7-005JGE S/N R9-0A95E2 14/09
    • alirafee
      • Jun 2015
      • 94
      • iran
      #42
      hi
      Need BIOS
      MB: LMQ-1
      12298-2
      48.4LY07.021
      16MB
      20a8
      no dis
      backup
        • 22236
        serial number -> https://www.badcaps.net/forum/showthread.php?t=103570
        • hoaca388
          Badcaps
          • Jan 2022
          • 12432
          #44
          X1 Carbon 2nd Gen Laptop (ThinkPad) - Type 20A7
          • mrkmpn
            Lenovo X1 Carbon 7th Gen Type 20R1 BIOS DUMP
            by mrkmpn
            SN: PF1Y5BBJ
            Board: GX490 NM-C661 Rev: 1.0
            I have made two dumps of this bios, with the bios chip removed from the board and the hashes match on both dumps, but I cannot find the DMI information in the dumps except for the Windows product key, so I think it is corrupted. I have downloaded two bios updates from the Lenovo support site, but they contain small .PAT file, and 4 subfolders containing .FL1 and .FL2 files, which I don't understand enough to figure out how to use to fix my dump.
            The problem with the laptop is that...
            05-21-2024, 09:14 AM
          • Joluvillas
            Lenovo ThinkPad L15 Gen 1 i7 (20U4) Bios and EC dump needed
            by Joluvillas
            Hi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
            06-18-2024, 10:35 PM
          • AHmad_Salal
            Need BIOS Dump/ROM for Lenovo Thinkstation p500
            by AHmad_Salal
            Hello all,
            I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
            11-28-2023, 05:28 AM
          • DynaxSC
            by DynaxSC
            11-17-2023, 10:56 AM
          • TacticalFahrrad
            [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
            by TacticalFahrrad
            I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
            06-30-2025, 04:09 AM
