Macbook Air 1466 EMC2925 password
  • DenzFlores
    • Jan 2022
    • 21
    • Philippines
    Re: Macbook Air 1466 EMC2925 password
    Originally posted by bluestone
    Use this, do PRAM rest after flashing
    Hi sir. Thank very much. I will try this one. You mean i will do PRAM reset after flashing?
    • bluestone
      • Jun 2011
      • 343
      • Ghana
      Yes
      • DenzFlores
        • Jan 2022
        • 21
        • Philippines
        Thank you very much sir. I will try this. You mean PRAM reset after i flash??
        • DenzFlores
          • Jan 2022
          • 21
          • Philippines
          Thank you... :-)
          • DenzFlores
            • Jan 2022
            • 21
            • Philippines
            @bluestone i tried your BIN File still no luck. The padlock is still there. I Tried reset the PRAM for more than 3x after flash but still locked up.
            • DenzFlores
              • Jan 2022
              • 21
              • Philippines
              #26
              Yes
              I tried the normal boot. This is what happened...
              • DenzFlores
                • Jan 2022
                • 21
                • Philippines
                #27
                Yes
                I tried the bin file of ala_borbe in the post #4. The efi lock is not present anymore... But the problem it is stuck in the apple logo. I am wondering why
                • peste
                  • Dec 2016
                  • 12868
                  • ROMANIA
                  #28
                  Re: Macbook Air A1466 EMC2925 EFI LOCK
                  Good day to all. I am a newbie here. Can someone help me to remove the EFI password of this BIN file? My customer forgot the password of this. Thank you in advance. God Bless.
                  try...
                  • DenzFlores
                    • Jan 2022
                    • 21
                    • Philippines
                    #29
                    Originally posted by peste
                    try...
                    Thank you sir peste. I already fixed the problem with clean ME region. I will post the file sir so others can use it too...
                    • DenzFlores
                      • Jan 2022
                      • 21
                      • Philippines
                      #30
                      This one really solved my problem. No password and the ME region is Cleaned.
                      • Buzzfuzz2k
                        Bios password removal on a Unowhy dump
                        by Buzzfuzz2k
                        Hi Everyone,
                        I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                        The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                        the Computer is a Unowhy small pc
                        N° UYM6524702229
                        After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                        My first attempt was to get the bios dump from windows...
                        11-13-2023, 07:37 AM
                      • mferna14
                        Password removal on MacBook Pro A2159
                        by mferna14
                        Hi friends., I am working on MacBook Pro A2159 touchbar 2019. The old logic board was liquid spilled so I ordered another logic board from AE. Received it & all worked fine till I got to the Chinese login screen where the login screen password tobe entered. I tried to reset the password but it again gave me options which I do not know about the Apple ID. I formatted the onboard SSD. & wanted to change the startup boot sequence but in order to change it, again the password is needed for that too. Is there a way to get rid of this password?? The seller has not replied back past 2 days, how...
                        05-13-2025, 04:16 PM
                      • ritalo
                        MacBook Air 13 2014 - Remove EFI password
                        by ritalo
                        I have a MacBook Air 13 inches 2014.
                        I have set a EFI password and I can't remember it : now I want to reinstall macOS and I can't because the MacBook is asking for the password.
                        I know how to remove the password with a usb programmer.
                        I plug the usb programmer to the motherboard and to my pc with usb, I read the EFI and I save it to a file.
                        Then I have to find this value in the file : $SVS because it indicate where is the password.
                        But I can't find the value.
                        I have attached the file​
                        Thank...
                        05-14-2024, 12:10 PM
                      • Danielreinaa
                        HELP need password bios Macbook A1706
                        by Danielreinaa
                        Hola chicos, espero estén bien, he estado buscando información para aprender a hacer eliminación de password EFI en macbooks.
                        Actualmente tengo un problema con una macbook pro A1706 820-00923 SN:C02VD3GJHV2Q
                        Si podrian ayudarme les agradeceria mucho o algun link para aprender a hacerlo y no volver a molestarles.
                        gracias de antemano y que tengan una linda tarde, disculpen si estoy rompiendo alguna norma.
                        Hi guys, I hope you are doing well, I have been looking for information to learn how to remove the EFI password on macbooks.
                        09-07-2024, 03:47 PM
                      • Nopslide
                        by Nopslide
                        04-01-2024, 04:27 PM
