Macbook Air 1466 EMC2925 password
  • dspok
    • Jan 2014
    • 553
    • Nepal
    Customer forgot efi password of Macbook Air 1466 EMC2925. So, please somebody remove efi password from attached dump.
  • imranromi
    • Jan 2015
    • 1288
    • Pakistan
    Re: Macbook Air 1466
    Here try this and reply.
    • dspok
      • Jan 2014
      • 553
      • Nepal
      @imranromi
      reprogrammed dump attached by you. Machine won't turn, turns on with original dump.
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        try this
        Im Back... sort of...
        • dspok
          • Jan 2014
          • 553
          • Nepal
          @ala_borbe
          Thanks it worked.
          Can anyone teach me about how to remove password?
          • Pascal Komlassan
            • Jan 2017
            • 809
            • TOGO
            Originally posted by dspok
            @ala_borbe
            Thanks it worked.
            Any help ?
            • smali
              • Sep 2014
              • 287
              • Pakistan
              Originally posted by Pascal Komlassan
              Any help ?
              Use hexaeditor tool open the file and search SVS and fill with ff for everything there usually found two times in dump or
              Simple way compare the lock and unlock file in hexaeditor find the difference.
              • DenzFlores
                • Jan 2022
                • 21
                • Philippines
                Macbook Air A1466 EMC2925 EFI LOCK
                Good day to all. I am a newbie here. Can someone help me to remove the EFI password of this BIN file? My customer forgot the password of this. Thank you in advance. God Bless.
                • Vesko356
                  VIP Moderator
                  • Aug 2018
                  • 4386
                  • Bulgaria 🇧🇬
                  Re: Macbook Air A1466 EMC2925 EFI LOCK
                  Become a Badcaps supporter
                  Thanks to all supporters.
                    • 20966
                    Read post #7 ,compare the differences between your backup and the unlocked one posted by Vesko https://mh-nexus.de/en/hxd/
                    • DenzFlores
                      • Jan 2022
                      • 21
                      • Philippines
                      Originally posted by Vesko356
                      Thank you so much. I will try this one... Hope it works..
                      • DenzFlores
                        • Jan 2022
                        • 21
                        • Philippines
                        Thank you sir...
                        • DenzFlores
                          • Jan 2022
                          • 21
                          • Philippines
                          Not working sir. It is still locked. Thank you sir. I appreciate this.
                          • DanielDacko
                            • Mar 2015
                            • 325
                            • Macedonia
                            Re: Macbook Air 1466 EMC2925 password
                            Here you go.
                            I don't provide help for people using CH341A and a clip.
                            • DenzFlores
                              • Jan 2022
                              • 21
                              • Philippines
                              Originally posted by DanielDacko
                              Here you go.
                              Thank you so much sir. I will try this and give feedback later
                              • DenzFlores
                                • Jan 2022
                                • 21
                                • Philippines
                                Here you go.
                                I flashed it already. Still the efi password is there... ��. Thanks a lot sir. Appreciate your work...
                                • Vesko356
                                  VIP Moderator
                                  • Aug 2018
                                  • 4386
                                  • Bulgaria 🇧🇬
                                  Post screenshot.
                                  • DenzFlores
                                    • Jan 2022
                                    • 21
                                    • Philippines
                                    Post screenshot.
                                    This is the picture after i flash. Still have lock
                                    • DenzFlores
                                      • Jan 2022
                                      • 21
                                      • Philippines
                                      Post screenshot.
                                      I have tried another BIN file, which is posted in other thread. After the flash there is no efi password. But the problem it is stuck up in the apple logo. after 2 hours nothing happen. This is the picture sir...
                                      • bluestone
                                        • Jun 2011
                                        • 343
                                        • Ghana
                                        Use this, do PRAM rest after flashing
                                        • Buzzfuzz2k
                                          Bios password removal on a Unowhy dump
                                          by Buzzfuzz2k
                                          Hi Everyone,
                                          I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                                          The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                                          the Computer is a Unowhy small pc
                                          N° UYM6524702229
                                          After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                                          My first attempt was to get the bios dump from windows...
                                          11-13-2023, 07:37 AM
                                        • mferna14
                                          Password removal on MacBook Pro A2159
                                          by mferna14
                                          Hi friends., I am working on MacBook Pro A2159 touchbar 2019. The old logic board was liquid spilled so I ordered another logic board from AE. Received it & all worked fine till I got to the Chinese login screen where the login screen password tobe entered. I tried to reset the password but it again gave me options which I do not know about the Apple ID. I formatted the onboard SSD. & wanted to change the startup boot sequence but in order to change it, again the password is needed for that too. Is there a way to get rid of this password?? The seller has not replied back past 2 days, how...
                                          05-13-2025, 04:16 PM
                                        • ritalo
                                          MacBook Air 13 2014 - Remove EFI password
                                          by ritalo
                                          I have a MacBook Air 13 inches 2014.
                                          I have set a EFI password and I can't remember it : now I want to reinstall macOS and I can't because the MacBook is asking for the password.
                                          I know how to remove the password with a usb programmer.
                                          I plug the usb programmer to the motherboard and to my pc with usb, I read the EFI and I save it to a file.
                                          Then I have to find this value in the file : $SVS because it indicate where is the password.
                                          But I can't find the value.
                                          I have attached the file​
                                          Thank...
                                          05-14-2024, 12:10 PM
                                        • Danielreinaa
                                          HELP need password bios Macbook A1706
                                          by Danielreinaa
                                          Hola chicos, espero estén bien, he estado buscando información para aprender a hacer eliminación de password EFI en macbooks.
                                          Actualmente tengo un problema con una macbook pro A1706 820-00923 SN:C02VD3GJHV2Q
                                          Si podrian ayudarme les agradeceria mucho o algun link para aprender a hacerlo y no volver a molestarles.
                                          gracias de antemano y que tengan una linda tarde, disculpen si estoy rompiendo alguna norma.
                                          Hi guys, I hope you are doing well, I have been looking for information to learn how to remove the EFI password on macbooks.
                                          09-07-2024, 03:47 PM
                                        • Nopslide
                                          by Nopslide
                                          04-01-2024, 04:27 PM
