Lenovo G50-80 tested ec and main bios needed
  • ganeshcell
    • Jan 2014
    • 80
    • india
    Motherboard part no is ACLU3/ACLU4 NM-A361 Rev 1.0
    Tested ec and main bios file needed.
    plz help
  • sriram
    • Dec 2017
    • 6
    • India
    Re: Lenovo G50-80 tested ec and main bios needed
    i want need lenovo G 50-80 bios programming 64bit motherboard part no NM-A361
    • p7comuter
      • Mar 2015
      • 75
      • Philippines
      Stock/orig bin for
      aclu3/aclu4 nm-a361 rev 1.0 2014-10-10
      core i7/amd gpu
      • Vincenzo 1962
        • May 2020
        • Italia
        Hi, I'm new to the forum, I would like information the bios lenovo g50-80 core i7 is different from the core i5.
        I am looking for that i5.
        https://translate.google.com
        • ümit levent
          • May 2017
          • türkiye
          Originally posted by p7comuter
          Stock/orig bin for
          core i7/amd gpu
          tnk
          • memoslar
            • Apr 2015
            • 122
            • Greece
            Guys i need help. I have a NM-A361 board. I had black screen. I updated the bios from user p7comuter. His bios was for i7 cpu. My cpu is i3.
            After the successful update i have this issue. Look at the pictures. I have particles when it starts but after that without the hard disk, the DOS mode works good. But it can't proceed in windows.
            I have changed also ram..
            • techman1025
              • Jun 2014
              • 497
              Hi you can't just take a bios from another machine FIRST it will have a dirty ME REGION Once a computer boot it's marred to that computer unless it a full new downloaded bios from lenovo or you rebuild ME REGION. Unplug internal cmos battery for like a min plug back in see if it boots . Or put original firmware bios back see if it boots to an external monitor if yes either go to dell download and do the update with in windows if no boot you need use a external programmer and i will upload you a new clean file.
              Techman1025
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                @memoslar, have you checked bios settings for Legacy and UEFI?? Hdd not detecting may be a bios setup issue as well. @techman1025 is right about me-region issue ,so do flash a lenovo virgin bios for your mb or make a request at bios section(A working clean me bios will be equally good). But the garbage display in the pic at post#9 worries me-is that indicating some other problem?? MB is discrete or UMA??
                • memoslar
                  • Apr 2015
                  • 122
                  • Greece
                  It is discrete graphics...
                  • ahmetamor
                    • May 2019
                    • turkey
                    hi myfriend bios rar can not open
                    please help
                      • 21936
                      please help
                      Use winrar or 7-zip to extract the file.If you already have either software then update it to the latest version.
                      • ahmetamor
                        • May 2019
                        • turkey
                        thank you its open 7-zip
                        • raileanu
                          • Sep 2015
                          • 127
                          HELLO PLEASE VERY URGENT !!! Does anyone have the working EC bios and Main bios for this model G50-80 with discrete graphic card? I try from G50-30 but is not the same I have the same problems with scrambled screen and not loading windows or bios setting. Only the startup screen shows. Before it was o corrupt bios and EC but what I found on internet doesn't';t work. Also if can someone show a picture of the pin out for ISP cable to program the ITE trough keyboard connector with RT809H.
                          I found everything here but don't have account there nor the option to register now.
                          https://************/threads/g50-80-nm-a361.14518/
                          MANY THANKS IN ADVANCE
                          • raileanu
                            • Sep 2015
                            • 127
                            It is i3 G50-80 with discrete graphic card
                            • peste
                              • 13630
                              • ROMANIA
                              try..
                              https://www.badcaps.net/forum/showthread.php?t=70949
                              if it doesn't work, post the original bios
                              • multix
                                • Sep 2017
                                • turkiye
                                Originally posted by peste
                                try..
                                Hi, my board G50-80 i3-Amd Gpu A361 v1.0 and your posted Clean Me bios worked for me. Thank u very much...
                                • jimore
                                  • Nov 2020
                                  • 179
                                  • mexico
                                  try..
                                  no display bios try help me clean.
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 12333
                                    This is a virgin bios with your DMI, if it not work then you have other issue, not cause bios.
                                    • oualid
                                      • Aug 2016
                                      • 49
                                      • españa
                                      Hello, I need bios for bios nm-a361 rev 1.0. I've tried these out there and they don't work for me. The equipment turns on for 3 seconds and turns off with its original bios, it does not turn off but it does not show an image.
                                      Attached original bios
                                      • hardware1
                                        • Sep 2021
                                        • 2948
                                        • N/A
                                        Latest version from Lenovo website, try it and let me know.
                                        all donations are welcome,
