Hello, i have a Samsung NP300E4E-A04VE with no boot devices show issue (dont boot from hdd, dvd, usb, also it didnt show devices in boot device priority) , i read in youtube that the solution is take apart the bios chip desoldering, reprogram the chip with the bios P02RBD and then solder the chip again to the motherboard. Can anyone help me with the bios dump in .rom or .bin? Thanks a lot for all the help!
Please, P02RBD BIOS for NP300E4E-A04VE
Re: Please, P02RBD BIOS for NP300E4E-A04VE
Here is a working dumpAttached Filesif you find these attachements useful please consider making a small donation to the site
what's this bios version? My laptop comes from factory with P02RBD (bios and micom) and in the RAM Sticker it says P02RBD. It´s Just Flash the bios that you give to me with a USB EEPROM programmer? or i need to edit something in the file?Comment
this is the p02rbd working bios dump
https://www.badcaps.net/forum/attach...6&d=1506547774
by DynaxSCHi
I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6... -
by JoWedHello Community,
I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...-
Channel: BIOS Requests ONLY!
by acedogblastThis is a guide that I am writing for helping others to replace their MEC1503 EC chip if it breaks (or to get around an inconvenient prompt to the BIOS). This forum has been extremely helpful to me so I would like to contribute to help others. I will tell you right now that this task is very difficult to do. You MUST have experience and tools to do precision micro-soldering, BGA reballing, trace repair, and general laptop repair skills.
There are some specialty tools needed to do this task. The replacement MEC1503 chips can be acquired from Aliexpress. Do not buy the bare chips as... -
My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
- I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
- I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
- I could only locate two chips that look like bios chips. Could someone verify this
by capoplaysHey everyone,
I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
When I check the BIOS using the F12 menu Flash...-
- Loading...
