Fail to BIOS Program WINBOND W25Q64FVSSIG 1.8V with SkyPro or CH341A
  • sn4k3
    • Oct 2016
    • 68
    • Portugal
    I have a laptop with corrupted BIOS that i can't program. I even buy new chips but without success of flash correctly
    I have SkyPro and CH341A with two 1.8V adaptor.
    Skypro seens not compatible, it don't have the chip on list, i tried to use the W25Q64FW but doesn't work.
    So i end with CH341A v1.29 that have the W25Q64FV. It appear to correctly erase and blank the chip, even the read and write operation works but when it verify the contents they are always in disagreement with the buffer and read from write output a messy hex combination.
    Anyone know a compatible chip that i can use on skypro list to flash this rom?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3600
    • slovakia
    Re: Fail to BIOS Program WINBOND W25Q64FVSSIG 1.8V with SkyPro or CH341A
    because of 1.8V dude
    u need adapter for 1.8V cmos
    • sn4k3
      • Oct 2016
      • 68
      • Portugal
      On main post i told i have two 1.8V adaptors, and yes i use them they are good
      The problem is my best programer (Skypro) does not have the chip under list and CH fails
      • GIFixed
        • Sep 2019
        • 61
        • Denmark
        I came across this thread and wondered:
        According to datasheet, the W25Q64FVSSIG should be 3V chip (2.7-3.6V) not 1.8V.
        • RethoricalCheese
          • Mar 2013
          • 1518
          • Estonia
          FV is 3.3V
          FW is 1.8V
          So you need to use a 3.3V programmer and pick W25Q64FV from the list.
          Are you programming on-board or did you unsolder it first?
          If on-board, you might need to apply power to motherboard.
          • GIFixed
            • Sep 2019
            • 61
            • Denmark
            Originally posted by The_Boss
            FV is 3.3V
            FW is 1.8V
            Thanks for info.
            But it is stated in the title of OPs thread "W25Q64FVSSIG" and he is trying to flash it with 1.8V.
            Thats what made me wonder.
            • intelg
              HP Elitedesk 800 G6 lost BIOS admin password
              by intelg
              Hello everyone, I am looking for help as I am struggling to remove lost BIOS Admin password on an HP EliteDesk G6 800 series desktop. I wanted to reset the vPro remote control IP kvm for homelab use.
              Here is the hardware identification specs:
              HP EliteDesk 800 G6 Desktop Mini PC
              Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
              BIOS ver S21 Ver. 02.05.01 01/05/2021
              Born on date: 07/26/2021
              SN MXL11841GN
              SKU 3X8V9UCHABA
              UUID 8116E79EF6FFE94DB0B98A3188270C5C
              SYSTEM BOARD ID 8710
              SYSTEM BOARD CT NUKBER PJLHQ0A8JF236L...
              11-03-2023, 02:05 AM
            • md500
              [Question] Ch341a and 5v to 3.3v with logic converter
              by md500
              zz0.8tpitu4y0i8zzI bought a ch341a (I'm waiting for it to arrive) and I noticed that the programmer has a bug that the data pins go to 5v when the VCC pin is at 3.3v (which is the voltage I'm looking for).
              Instead of doing the 3.3v mod, I'm thinking of converting the 5v to 3.3v with an 8 channel TXS0108E through the ZIF socket but I don't know if that would work, because it has to circulate voltage and also information.
              What I am looking for is something that will convert from 5v to 3.3v but without modifying the ch341a.
              I can't buy the ch341a 1.6v that has...
              05-24-2024, 06:51 PM
            • mnciks11
              How to use CH341A to program ENE io chip or startup chips
              by mnciks11
              Hello guys
              I've seen that it's possible to program the ENE chips using the CH341A programmer, one of my buddies was about to send me information how to do it but I lost his contacts…
              I have a gaming laptop with physical burnt ENE CHIP , the programmable one , can someone please guide me or send me information on how to do it .
              Thank you , I believe this will assist others...
              08-08-2022, 08:58 AM
            • praveenramavath
              Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
              by praveenramavath
              Hello All,
              I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
              https://www.hifivision.com/threads/m...-screen.98243/
              Troubleshooting Summary: Majority Internet Radio - Flash Chip
              04-26-2025, 09:08 AM
            • mccurly
              Archer C9 V.4 Can ch341a be used for programming a 16pin Winbond w25q128fv
              by mccurly
              Hello folks,
              (First post of mine, after introduction).
              I came here to seek help for a board SPI reprogramming.
              The referred board belongs to an Archer C9 V.4 EU router, which I believe, is bricked, (I was the one to brick it during a flashing operation with custom dd-wrt firmware upgrade).
              The IC that I want to flash is this one:
              Datasheet for the IC in question .
              The one in the motherboard has 16 pins. (There are other IC in the motherboard, with 8 pins each, but I am almost positive that the one that will...
              09-23-2021, 10:19 AM
