Dell Latitude E5570 bios needed
  • Markus1741
    • Sep 2020
    • 843
    • N/A
    #101
    Why UV9, but try this two files file UV9 + BIOS Me Clean file Good luck ...
    • ulrichvachon
      Ulrich
      • Oct 2024
      • 10
      • France
      #102
      Originally posted by ulrichvachon
      Furthermore, I managed to decompile the latest version of the BIOS found at DELL (Latitude_E5x70_Precision_3510_1.34.3.exe) and the :
      “1 Latitude_E5x70_Precision_3510_1.34.3 -- 1 System BIOS with BIOS Guard v1.34.3.bin” and ‘1 Latitude_E5x70_Precision_3510_1.34.3 -- 2 Embedded Controller vA.24.bin'. I thought I could flash my two chips with these files but the size of the file “1 Latitude_E5x70_Precision_3510_1.34.3 -- 1 System BIOS with BIOS Guard v1.34.3.bin” is only 9 MB. And when I flashed with this file nothing happened on the machine. I am lost.
      Thanks SMDFlea for your reply. I guess there is a way to merge this partial bios in my backup (UC 6). I'll look into it. Is the file for EC (1 Latitude_E5x70_Precision_3510_1.34.3 -- 2 Embedded Controller vA.24.bin) also partial according to you?​
      • ulrichvachon
        Ulrich
        • Oct 2024
        • 10
        • France
        #103
        Thanks Markus1741 I'll try that faster !
          • 20898
          I would suggest you leave the EC well alone, just flash the files Markus gave you and hopefully (fingers crossed) you`ll have a working laptop
          • ulrichvachon
            Ulrich
            • Oct 2024
            • 10
            • France
            #105
            Hello Markus1741 SMDFlea
            It works! Thanks again for bringing the machine back to life. But I'd really like to know how you did it? I've tried all kinds of files and combinations, but to no avail for days. I don't know if this is the right topic to talk about this but as a Software Engineer I'd like to know how you were able to find/generate the right files ? Is it something to do with the "Service tag" or something else? What software or code did you use?
            Thank you very much.
            PS : I've flashed the two files.
            • Markus1741
              • Sep 2020
              • 843
              • N/A
              #106
              nice to hear that it worked.
              First of all, research where the BIOS chip is located. Only then start reading.
              You can look for a circuit diagram in your case Dell LA-C641P can also be found in this forum.
              If you have the opportunity, it's always a good idea to unsolder the BIOS chip.
              CH341A with clip is always a gamble, I don't like doing it.
              It is very important to create a good backup of the original BIOS.
              I usually make three backups.
              I unsoldered the UV9 chip from my notebook and read it three times and then compared the contents with md5sum.
              The main BIOS was a BIOS from a notebook that I have here.
              You should just do an ME Clean of the Intel firmware before making it available to others. Everything else can be found here in the forum or on the Internet.
              Good luck continuing
              • ulrichvachon
                Ulrich
                • Oct 2024
                • 10
                • France
                #107
                Thank you again Markus1741 took time for unsoldering your chip for me ! I knew that using climbs is not the good idea but I wanted to test with them before to buy more material. Indeed I did two backups of UC6 and forgot to backup the UV9 (big mistakes!).
                I read more about ME Clean and I understood the goal of this operation now Probably that they were a corruption in the region...
                Have a good evening.
                • casaba
                  • Apr 2014
                  • 25
                  • morokko
                  #108
                  thanks
                  • Lubazi
                    • Apr 2024
                    • 14
                    Hello i need a working BIOS for my DELL E5570.
                    I have attached the original bios, I have already tested several but none worked.
                    The lamp lights up 2 times orange and 1 time white.
                    Thank you for any help
                    Mainboard:
                    ADP80 LA-C841P
                    Rev:3.0 (A02)
                    SERVICE TAG: G6N7Q72
                      SMDFlea commented
                      Editing a comment
                      Thread merged.
                  • jymmytuan95
                    • Jan 2021
                    • 30
                    • Viet Nam
                    #110
                    i need build bios fix not detect wifi.
                    service tag : DTSZMC2
                    • Cire3PC
                      • Jan 2019
                      • 8
                      Looking for some help, Dell Latitude E5570
                      Service Tag : 98QMWF2
                      Power button lights up with charger plugged in, however nothing happens. Tried a couple files here and it actually started to post and ended with error about a Flash Failure ?
                      Attached I have the original BIOs dump.
                      I won't ever demand, but kindly ask for the BIOs Gods to help
                      Thanks in advance for any direction.
                      • its service
                        • Feb 2021
                        • 139
                        • india
                        #112
                        Originally posted by valieromarco
                        Re: Dell Latitude E5570 bios nedded
                        Try this, it works perfectly.
                        Thanks bro working perfectly
                        • Cire3PC
                          • Jan 2019
                          • 8
                          That is for all E5570's then I assume? I'll give it a go.
                          • ak1_2004
                            • Oct 2017
                            • 41
                            • Iran
                            #114
                            The laptop turns on, and all voltages are present, but the display appears randomly.
                            The BIOS dump file is attached.
                              • 20898
                              Post the full laptop model number and service tag, please read the rules - https://www.badcaps.net/forum/troubl...before-posting
                              • ak1_2004
                                • Oct 2017
                                • 41
                                • Iran
                                #116
                                DELL E5570 C841P
                                ST : GFQWYF2
                                • peste
                                  • Dec 2016
                                  • 12812
                                  • ROMANIA
                                  #117
                                  Dell 5570 or 5530???
                                  • ak1_2004
                                    • Oct 2017
                                    • 41
                                    • Iran
                                    #118
                                    Dell 5570
                                    • LBTT1121
                                      • Nov 2024
                                      • 531
                                      • Việt Nam
                                      #119
                                      Dell 5570
                                      try and feedback
                                      • redbaron1007
                                        • Jun 2021
                                        • 107
                                        I'm looking for a bios for an E5570. I'm suspecting the one on the board I have is the reason it isn't booting.
                                        Board ADP80 LA-C841P
                                        I don't have a serial number for the laptop the tag on the back with it is missing. All I have is the model E5570 and P48f001.
                                          DELL Latitude E5570 Notebook 5000 Specification for Upgrade or Repair
                                          This specification for the DELL Latitude E5570 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E5570 boardview and E5570 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude...
                                          09-06-2024, 04:40 PM
