Asus P50IJ Bios dump
  • Pascal Komlassan
    • Jan 2017
    • 806
    • TOGO
    Hello please I need the bios dump of this machine
  • cacla
    • Apr 2015
    • 442
    Re: Asus P50IJ Bios dump
    try this one
    • Pascal Komlassan
      • Jan 2017
      • 806
      • TOGO
      thank's bro it's working
      • cacla
        • Apr 2015
        • 442
        you are welcome
        • Pascal Komlassan
          • Jan 2017
          • 806
          • TOGO
          �� I'm so glad thanks very much
          • razor_amd
            by razor_amd
            12-15-2020, 07:07 PM
          • DynaxSC
            by DynaxSC
            06-14-2024, 03:49 PM
          • jbonavita
            by jbonavita
            Some issues
            Things I tried
            04-29-2025, 09:38 PM
          • Habble7
            by Habble7
            Suspected Cause:
            Troubleshooting Attempts:
            05-22-2025, 07:28 AM
          • Anchar777
            ASUS P1412CE need BIOS DUMP
            by Anchar777
            Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
            06-26-2025, 03:39 AM
