Firmware password on A1286 820-2850 A EMC2353
  • daanix
    replied
    Re: Firmware password on A1286 820-2850 A EMC2353
    hy all , i had this model in service and i managed to obtain the bios , i have 2 bioses , the first one is a backup bios from the laptop no password and i managed to modify ME , it start but in my case a have no backlight on display , with second bios i have backlight , but the bios had a password and i managed to research and find it and is 200959 , i hope will help you , i will put the link for the tutorial : https://www.youtube.com/watch?v=2uqpJjQDmq8
    Pre 2011 Apple Mac Firmware Password Removal
    1.) DUMP EFI ROM from a EFI Locked mac (PRE 2011 Models) using a BIOS programmer
    2.) Search the below HEX inside the Rom using a Hex Editor (Try HxD) :
    730065006300750072006900740079002D00700061007300730077006F0072006400
    3.) Copy the Hex Between "00 00" "AA 55 7F" or "AA 55 7D" from the HEX Editor
    4.) Go to http://halflight.com.au/wp-content/u...8/macHash.html
    5.) Paste the copied HEX code in to the Hash input field with % instead of spaces between HEX and click Decode. You'll have your password decoded. Enjoy!
    -=] Game Over! [=-
  • peste
    replied
    Originally posted by Philip70 View Post
    Please someone should help me with 820-2850-A clean bios
    post the original bios
  • Philip70
    replied
  • imgaurav86
    replied
    Originally posted by ala_borbe View Post
    this is older 4mb bios... easy to remove
    see this
    Code:
    https://itcrush.wordpress.com/2012/04/14/how-to-bypass-apples-efi-password/
    Thanks alot Ala_borbe. That worked
  • ala_borbe
    replied
    see this
    Code:
  • imgaurav86
    replied
    read dump and post here
    Thanks Ala_borbe
    The dump is attached.
  • ala_borbe
    replied
  • imgaurav86
    started a topic Firmware password on A1286 820-2850 A EMC2353
    Hi Everyone,
    Can someone please explain how can I remove firmware password from Mac-book A1286 820-2850 A EMC2353 i5 2.53ghz .
    Do I need to flash the new dump? or I can remove the password from old dump using some method?
    If I use the dump from ghostly hacks and replace the serial number would it work fine?
    Thanks in advance
