Firmware password on A1286 820-2850 A EMC2353
  • imgaurav86
    • May 2008
    • 35
    Hi Everyone,
    Can someone please explain how can I remove firmware password from Mac-book A1286 820-2850 A EMC2353 i5 2.53ghz .
    Do I need to flash the new dump? or I can remove the password from old dump using some method?
    If I use the dump from ghostly hacks and replace the serial number would it work fine?
    Thanks in advance
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: Firmware password on A1286 820-2850 A EMC2353
    read dump and post here
    Im Back... sort of...
    • imgaurav86
      • May 2008
      • 35
      Thanks Ala_borbe
      The dump is attached.
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        this is older 4mb bios... easy to remove
        see this
        Code:
        https://itcrush.wordpress.com/2012/04/14/how-to-bypass-apples-efi-password/
        • imgaurav86
          • May 2008
          • 35
          see this
          Code:
          Thanks alot Ala_borbe. That worked
          • Philip70
            • Aug 2017
            • Nigeria
            Please someone should help me with 820-2850-A clean bios
            • peste
              • 13768
              • ROMANIA
              post the original bios
              • daanix
                • 14
                • romania
                hy all , i had this model in service and i managed to obtain the bios , i have 2 bioses , the first one is a backup bios from the laptop no password and i managed to modify ME , it start but in my case a have no backlight on display , with second bios i have backlight , but the bios had a password and i managed to research and find it and is 200959 , i hope will help you , i will put the link for the tutorial : https://www.youtube.com/watch?v=2uqpJjQDmq8
                Pre 2011 Apple Mac Firmware Password Removal
                1.) DUMP EFI ROM from a EFI Locked mac (PRE 2011 Models) using a BIOS programmer
                2.) Search the below HEX inside the Rom using a Hex Editor (Try HxD) :
                730065006300750072006900740079002D00700061007300730077006F0072006400
                3.) Copy the Hex Between "00 00" "AA 55 7F" or "AA 55 7D" from the HEX Editor
                4.) Go to http://halflight.com.au/wp-content/u...8/macHash.html
                5.) Paste the copied HEX code in to the Hash input field with % instead of spaces between HEX and click Decode. You'll have your password decoded. Enjoy!
                -=] Game Over! [=-
                • Ahari
                  by Ahari
                  I...
                  08-13-2025, 06:12 AM
                • Buzzfuzz2k
                  Bios password removal on a Unowhy dump
                  by Buzzfuzz2k
                  Hi Everyone,
                  I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                  The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                  the Computer is a Unowhy small pc
                  N° UYM6524702229
                  After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                  My first attempt was to get the bios dump from windows...
                  11-13-2023, 07:37 AM
                • dell_bios
                  Need unlocked BIOS dump for W25Q64FV (Admin Password removal)
                  by dell_bios
                  I'm working on removing an administrative BIOS lock (Supervisor/Admin Password) on a laptop.
                  The board has three SPI flash chips:
                  - W25Q64FV (main BIOS)
                  - W25Q32FV (EC/TPM)
                  - W25X10CL (configuration)
                  I was able to read the dump from the W25Q64FV chip, CRC32 = 0x3DE23E27.
                  The dump contains protection that needs to be removed.
                  If anyone has a clean or unlocked BIOS dump for W25Q64FV, I’d really appreciate it!
                  I’m also happy to share my dump for comparison if needed.
                  Laptop model: [please specify, e.g....
                  10-16-2025, 04:28 PM
                • Tamo Neko
                  Request for MX25VB8035F (1MB) Firmware Dump – Asus TUF Gaming H670-Pro
                  by Tamo Neko
                  I'm working on an Asus TUF Gaming H670-Pro motherboard and need help finding a firmware dump for the MX25VB8035F (1MB) SPI flash chip.
                  What Happened:
                  I mistakenly removed and erased this 1MB chip, thinking it was part of the main BIOS.
                  • I later found that the board has two main BIOS chips (8MB + 16MB), which I have backups for.
                  • My backup for the MX25VB8035F chip is just an empty 1MB segment filled with FFs, meaning I have no valid data to restore.
                  What I Need:
                  • A firmware dump for the MX25VB8035F chip from the same motherboard (or a compatible
                  02-12-2025, 11:29 PM
                • jorpec
                  Dump/Firmware needed TV Kunft 19CG86813 Board T.EME380.61 Panel ECG185BB-LC4
                  by jorpec
                  Hi, all
                  I need the dump/firmware for this tv, it was on a boot loop, i dont have the original corrupted dump because i used a pen drive with a firmware that solved the boot loop, initially it seemed it was ok but the tv has no sound
                  10-17-2025, 03:51 AM
