Apple MacBook Pro A1502 (820-3476-A)
  • ljamal74
    • May 2016
    • 7
    • France
    #61
    Re: Apple MacBook Pro A1502 (820-3476-A)
    Our two files are identical except for our series blocks which are different.
    my problem was hibernation mode can write any bios to my laptop and just write serial number to the file and correct the checksum?
    i still request help sur mon probleme post 54.
    thanks to all who can help me.
    • ljamal74
      • May 2016
      • 7
      • France
      #62
      bios corrupted need help repair
      bump
      • ljamal74
        • May 2016
        • 7
        • France
        #63
        any bro. can help me plz.
        • volinakis
          • Jan 2021
          • 2809
          • N/A
          #64
          Originally posted by mientowy
          I entered the SN into the file. I need to correct the checksum. Can someone help me?
          SN: C02NRFEKG3QH
          here
          • jojomomo1974
            • Nov 2023
            • 3
            • maroc
            #65
            macbook pro bios dump needed.
            I have this macbook pro Mid 2014 :
            main board n° : 820-3476-A
            Main-Board : 820-3476-A
            Serial n° : C02NF2AJG3QT
            EMC2875
            that does not start after installing Windows 10.
            the bios may be corrupted.
            I would be grateful if anyone can help me solve this hosting problem.
            THANKS
            • farouk_1994
              • Mar 2021
              • 395
              • algeria
              #66
              Re: macbook pro bios dump needed.
              EMC2875
              THANKS
              Try this file with your SN than feedback
              • jojomomo1974
                • Nov 2023
                • 3
                • maroc
                #67
                ok thank you very much my brother farouk for the cleanMe file, I will try it and let you know the result.
                • julianjofre1
                  • Apr 2017
                  • 16
                  • argentina
                  #68
                  Hello good morning people! I ask you for help to unlock this bios efi please, it would be a great help!!
                  macbook pro a1502 emc 2835
                  motherboard:820-4924-A.
                  serial number: c2qrx05jgkjg
                  • MuertoGB
                    • Sep 2021
                    • 94
                    • United Kingdom
                    #69
                    Your firmware did not dump properly, too many 0xFF. Please do it again, and this time verify the dump with what is on the SPIROM.
                    • julianjofre1
                      • Apr 2017
                      • 16
                      • argentina
                      #70
                      there I read it again and verified plisss
                      • MuertoGB
                        • Sep 2021
                        • 94
                        • United Kingdom
                        #71
                        Sorry, could you upload your file again? I did unlock your file, but the forum upgrade wiped out attachments and my post.
                        • peste
                          • Dec 2016
                          • 13199
                          • ROMANIA
                          #72
                          try..
                          • beast4ever
                            • Feb 2015
                            • 174
                            • egypt
                            #73
                            nedd bios BIOS A1502 EMC 2835 820-3476-A
                            serial c02qh0f9fvh4
                            Unfortunately, the Ic is damaged and I cannot make a backup copy
                            The uploaded copy opens with the device
                            But do not read the hard drive or flash drive​
                            • beast4ever
                              • Feb 2015
                              • 174
                              • egypt
                              #74
                              serial c02qh0f9fvh4
                              up
                              Help please
                              • Xiran
                                • Jan 2019
                                • 47
                                • Qro
                                #75
                                Hi to all!
                                Can be posible, to do an efi firmware update manually? I've tried with Apple app without luck...
                                It's an a1502
                                0138.b15.150605072
                                I have a macbookpro11,1 who i revive from a water damage, i can use macos sierra normal from usb, but i can't install high sierra (yes, the firmware is not updated), somebody sells me, without turning on (only for pieces), but actually, i hopefully repair it, but don´t include the original ssd... =(, so i put an adapter.
                                i´ve tried to update directly the firmware with MACBRTOOL_V1.0.0_IMG, but no luck...
                                I've checked the list, and it appears:
                                MBP111_0142_B00_LOCKED.scap 82432 0142.00 MBP111 Mac-189A3D4F975D5FFC
                                Here are the pic:
                                • Xiran
                                  • Jan 2019
                                  • 47
                                  • Qro
                                  #76
                                  Hi friends!
                                  I have:
                                  Board-id: Mac-189A3D4F975D5FFC
                                  serial C17NX5F8G3QH
                                  EFI update please?
                                  I put the next firmware updated, but no constant power on...
                                  • peste
                                    • Dec 2016
                                    • 13199
                                    • ROMANIA
                                    #77
                                    Originally posted by Xiran
                                    Hi friends!
                                    I have:
                                    serial C17NX5F8G3QH
                                    EFI update please?
                                    Try..
                                    • Xiran
                                      • Jan 2019
                                      • 47
                                      • Qro
                                      #78
                                      Originally posted by peste
                                      Try..
                                      Thx for answer peste!
                                      ARe there some efi Shell Commands to do the task? For not desolder and resolder the chip... =(
                                      • Xiran
                                        • Jan 2019
                                        • 47
                                        • Qro
                                        #79
                                        Try..
                                        Excuse me peste, but it don´t have the apfs driver... =(
                                        • Xiran
                                          • Jan 2019
                                          • 47
                                          • Qro
                                          #80
                                          Ok, here comes god news, with this file i can install high sierra (with apfs driver dxe), but doesn't detect wifi card...
