HP Compaq 6715b BIOS dump need
  • alas3376
    • Nov 2011
    • 382
    • BENIN
    Hello everybody, need BIOS bin of this:
    HP Compaq 6715b
    6050a2142101-mb-a05
    Thank you
  • alas3376
    • Nov 2011
    • 382
    • BENIN
    Re: HP Compaq 6715b BIOS dump need
    Still waiting !!!!!!!!!!!
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      backup old bios and try this
      Im Back... sort of...
      • alas3376
        • Nov 2011
        • 382
        • BENIN
        Thank very much , god bless you
        • alas3376
          • Nov 2011
          • 382
          • BENIN
          Hello Mr ala_borbe , i tried but it not working. I think it s not the same.
          • Djosla
            • Dec 2012
            • 246
            • Montenegro
            what is wrong with your pc ?
            That rom that ala borbe posted is ok...from official site..
            • alas3376
              • Nov 2011
              • 382
              • BENIN
              Thank you Mr Djosla for answering
              Laptop start fine but No graphique. I reball it but same issue.
              • Djosla
                • Dec 2012
                • 246
                • Montenegro
                Than you have faulty gpu...yesterday i have replaced gpu on same model...These laptops usually doesn`t have bios issues...
                • alas3376
                  • Nov 2011
                  • 382
                  • BENIN
                  OK, i'm going to order another gpu,
                  • alas3376
                    • Nov 2011
                    • 382
                    • BENIN
                    here is the old bios dump, Mr ala_borbe could you plz help me to fix it
                    thank
                    • alas3376
                      • Nov 2011
                      • 382
                      • BENIN
                      thank
                      • alas3376
                        • Nov 2011
                        • 382
                        • BENIN
                        hello!!!!!!
                        need your help!!!!
                        looking forward your answer
                        thank you
                        • Habble7
                          by Habble7
                          Suspected Cause:
                          Troubleshooting Attempts:
                          05-22-2025, 07:28 AM
                        • DynaxSC
                          by DynaxSC
                          11-17-2023, 10:56 AM
                        • grimacelord
                          Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                          by grimacelord
                          This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                          Motherboard model number: DA0PAMB46A1 REV: A
                          Secondary motherboard model number: 0PAB
                          SKU: 685K4UA
                          Serial number is: 5CD3223BJP
                          Recently reflashed this laptop with latest BIOS and once...
                          05-07-2024, 08:06 AM
                        • DynaxSC
                          Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                          by DynaxSC
                          I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                          It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                          I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                          11-06-2022, 05:22 PM
                        • TacticalFahrrad
                          [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                          by TacticalFahrrad
                          I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                          06-30-2025, 04:09 AM
