HP MINI 210-2005tu bios
  • Romulo
    • Nov 2016
    • 484
    • Philippines
    hi everyone can someone help me to fix this bios dump for hp mini 210-2005tu chargelight and capslight blinking please ala borbe help me fix my dump please. i need this urgent.attached is my original dump
  • Romulo
    • Nov 2016
    • 484
    • Philippines
    Re: HP MINI 210-2005tu
    Update i manage to fix the bios i downloaded from the site and also fix the serial using hp nbdmifit netbook nw boots fine but i have one problem after shuts down cannot turn on again power led blinking but when i remove charger and rest for 5 to 10 mins and put it back boots fine and so on.what could it be the problem for this please help and advise.thanks in advance
    • Romulo
      • Nov 2016
      • 484
      • Philippines
      Any advise please what cause this problem?
      • keeney123
        Lauren
        • Sep 2014
        • 2536
        Most likely people would need to know your operating system and whether it is 64bit or 32 bit machine.
        • Romulo
          • Nov 2016
          • 484
          • Philippines
          Operating system installed is windows 10 32bit. What could be the prpblem with this?
          • Romulo
            • Nov 2016
            • 484
            • Philippines
            Any advise on this one thing also if i plugged in the battery charged light not turning on and cannot turn on
            • keeney123
              Lauren
              • Sep 2014
              • 2536
              So HP had a power cord replacement in 2014 this is the link to check the power cord.
              http://support.hp.com/us-en/product/...ent/c04404446/
              • keeney123
                Lauren
                • Sep 2014
                • 2536
                Did this system come with a different operating system? If it did come with a different OS did everything work correctly including the problem you are having?
                • keeney123
                  Lauren
                  • Sep 2014
                  • 2536
                  What Bios are you running?
                  • keeney123
                    Lauren
                    • Sep 2014
                    • 2536
                    So we want to eliminate any software possible problem before we look at the hardware.
                    I am not an active repair person, but will help you what I can. Perhaps someone who repairs these every day will contribute. I was an electronic Tech. some time ago and have worked mainly on hardware.
                    • Romulo
                      • Nov 2016
                      • 484
                      • Philippines
                      I think this is a hardware problem because works fine once i boots up even hours works fine but the only problem after shutting down plugged in again the adapter lights blinking i need to rest for 10 minutes to work again i use original hp charger
                      • Romulo
                        • Nov 2016
                        • 484
                        • Philippines
                        Any help please what is the problem for this?please help
                        • Romulo
                          • Nov 2016
                          • 484
                          • Philippines
                          Anyone please help
                          • snsent
                            • Nov 2010
                            • 103
                            • Malaysia
                            Some of this model with no display problem cause by CPU failure...
                            Please try to find LED blink code for HP / Compaq
                            • Romulo
                              • Nov 2016
                              • 484
                              • Philippines
                              There is a display the problem is after you shutdown cannot turn on again lights blinking but if you rest for 10 mins and start to plugged in the charger without battery it works again but if battery plugged in cannot turn on.and also cannot read flashdrive i already update bios to newest version also i reflowed ite and cpu.and advise please help
                              • keeney123
                                Lauren
                                • Sep 2014
                                • 2536
                                It is not necessarily a hardware problem. When booting up the software is using areas of it that are not used when running the machine. If it is a hardware problem we will need schematics. One thing you can check very easy is the plugged in power for your computer. After running it turn off the computer and unplug the power. Use a meter to check voltage coming out of the power cord. The cord converter box will have a DC Voltage written on it. This is what needs to come out the cord. Next take the battery out of the machine and just use the plug in power and see if the same thing happens. Then do the reverse and only have the battery in the computer and leave the cord off and see if the same thing happens.
                                • keeney123
                                  Lauren
                                  • Sep 2014
                                  • 2536
                                  Here is how to take it apart and put it back together. I will look for schematics.
                                  • keeney123
                                    Lauren
                                    • Sep 2014
                                    • 2536
                                    I can not readily find the schematics.
                                    • keeney123
                                      Lauren
                                      • Sep 2014
                                      • 2536
                                      Is the battery charged? Also, what bios do you have? HP does not guarantee this computer will work with Windows 10. Do you know if it worked alright with different OS?
                                      If the battery is discharged the OS will tell the computer what to do. You can find this in power options. It can shut down, hibernate or do nothing.
                                      • Romulo
                                        • Nov 2016
                                        • 484
                                        • Philippines
                                        Thanks for the response before os is windows 8 the problem with this laptop before bios also corrupted so i reprogram with new one i got on the hp site si netbook worka fine then i reformat to windows 10 wrks fine also after 4months customer came back tje same problem so i reprogram bios again cannot program so i chnange the bios chip now this is the problem works fine when charger only buy after shutting down cannot turn on again i need to rest for 10 mins to use it again
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          Yesterday, 05:12 AM
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
                                        • ruzhda
                                          Clean Bios dump for HP 260 G4 mini
                                          by ruzhda
                                          I am new in forum, working whit computers since Commodore 64 (own 2 defect units) And Amiga 1200,
                                          I taring to fix HP 260 G4 mini whit bios corrupted error , after reading and writing bios whit programmer pc is not powering on .
                                          I need clean dump to write new IC chip.
                                          07-21-2024, 08:10 AM
                                        • MDSI
                                          HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                                          by MDSI
                                          I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                                          Details:
                                          Model : HP OMEN 17-an012nf
                                          Motherboard Part Number : DAG3BAMBAF0 REV : F
                                          Serial Number (S/N) : 5CD7280D51
                                          BIOS chip : Winbond W25Q64VSIQ
                                          Programmer : EZP2023+
                                          Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                                          I already...
                                          07-28-2025, 07:11 AM
