hi everyone can someone help me to fix this bios dump for hp mini 210-2005tu chargelight and capslight blinking please ala borbe help me fix my dump please. i need this urgent.attached is my original dump
HP MINI 210-2005tu bios
Re: HP MINI 210-2005tu
Update i manage to fix the bios i downloaded from the site and also fix the serial using hp nbdmifit netbook nw boots fine but i have one problem after shuts down cannot turn on again power led blinking but when i remove charger and rest for 5 to 10 mins and put it back boots fine and so on.what could it be the problem for this please help and advise.thanks in advance -
So HP had a power cord replacement in 2014 this is the link to check the power cord.
http://support.hp.com/us-en/product/...ent/c04404446/Comment
So we want to eliminate any software possible problem before we look at the hardware.
I am not an active repair person, but will help you what I can. Perhaps someone who repairs these every day will contribute. I was an electronic Tech. some time ago and have worked mainly on hardware.Comment
I think this is a hardware problem because works fine once i boots up even hours works fine but the only problem after shutting down plugged in again the adapter lights blinking i need to rest for 10 minutes to work again i use original hp chargerComment
There is a display the problem is after you shutdown cannot turn on again lights blinking but if you rest for 10 mins and start to plugged in the charger without battery it works again but if battery plugged in cannot turn on.and also cannot read flashdrive i already update bios to newest version also i reflowed ite and cpu.and advise please helpComment
It is not necessarily a hardware problem. When booting up the software is using areas of it that are not used when running the machine. If it is a hardware problem we will need schematics. One thing you can check very easy is the plugged in power for your computer. After running it turn off the computer and unplug the power. Use a meter to check voltage coming out of the power cord. The cord converter box will have a DC Voltage written on it. This is what needs to come out the cord. Next take the battery out of the machine and just use the plug in power and see if the same thing happens. Then do the reverse and only have the battery in the computer and leave the cord off and see if the same thing happens.Comment
Here is how to take it apart and put it back together. I will look for schematics.Attached FilesComment
Is the battery charged? Also, what bios do you have? HP does not guarantee this computer will work with Windows 10. Do you know if it worked alright with different OS?
If the battery is discharged the OS will tell the computer what to do. You can find this in power options. It can shut down, hibernate or do nothing.Comment
Thanks for the response before os is windows 8 the problem with this laptop before bios also corrupted so i reprogram with new one i got on the hp site si netbook worka fine then i reformat to windows 10 wrks fine also after 4months customer came back tje same problem so i reprogram bios again cannot program so i chnange the bios chip now this is the problem works fine when charger only buy after shutting down cannot turn on again i need to rest for 10 mins to use it againComment
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
Hello engineers 😀,
I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
🔧 Device Info:
- Model: HP 15-da2007ne
- Product Number: 8XF55EA#ABV
- Serial Number: CND0338P0D
- CPU: Intel Celeron N4000
- EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
💀 Problem:😅
- Device shows “Administrator Password”...2 Photos-
Channel: BIOS Requests ONLY!
Today, 04:54 AM -
by CityminHi all,
S/N : 5RNK9FFT70...-
by DynaxSCHi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...11-17-2023, 10:56 AM -
by ruzhdaHi,
I am new in forum, working whit computers since Commodore 64 (own 2 defect units) And Amiga 1200,
I taring to fix HP 260 G4 mini whit bios corrupted error , after reading and writing bios whit programmer pc is not powering on .
I need clean dump to write new IC chip.
Thanks-
- Loading...
