Re: Lenovo G40-80 bios
thanks meritosari ill try this and feedback soon thank you
Lenovo G40-80 bios
Backup the old one, Try this:Attached Filesif you find these attachements useful please consider making a small donation to the site
Need help on this please share working bios file the problem on this laptop i need to remove and put it back the cmos battery in order to turns on and boots fine please helpLeave a comment:
I cannot download your files it says does'nt exist can you please upload it hereLeave a comment:
Ill aready done update the bios but evertime i shutdown cannot turn on again i need to remove cmos battery to turn on the laptop.please helpLeave a comment:
The problem with this laptop turns on and boots fine in windows aftet i shut down cannot turn on again But if you remove cmos battery and put it back it turns in fine after shut it dwn the same issue i need to remove at put back cmos battery to turn on.please helpLeave a comment:
Lenovo G40-80 bios
Hi everyone I need a working bios dump file for this model Lenovo G40-80 notherboard id:ACLU3/ACLU4 UMA NM-A362 REV 1.0 thanks in advanceTags: None
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
Channel: BIOS Requests ONLY!
08-12-2025, 03:01 PM -
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
by gestalt.exeHi everyone,
My Lenovo Legion Y540 (i7-9750H, RTX 2060) bricked after I downgraded from BHCN44WW to BHCN21WW.
Laptop stopped booting entirely.
I used a CH341A programmer to dump the corrupted 16MB BIOS.
i then attempted the following:- Downloaded stock BIOS BHCN39WW from Lenovo
- Trimmed it to 16MB
- Extracted the BIOS region from the corrupted dump
- Extracted the BIOS region from the stock 39WW
- Replaced the corrupted BIOS region with the stock one (within hxd , opened the corrupted dump and replaced its region by the stock)
- Injected back my LDGB / DMI
by grimacelordHello there.
I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
History:
1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
I searched for this error online and discovered...-
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
I have opened the laptop and identified the main BIOS chip...2 Photos-
- Loading...
