Lenovo G40-80 bios
  • andresi
    replied
    Re: Lenovo G40-80 bios
    Originally posted by andresi
    hi there, i've G40 bios lock, i try with autopatch but not working, anyone can help me ?
    Password gone after flashing #10
  • andresi
    replied
  • srinivas mallela
    replied
    Originally posted by meritosari
    Backup the old one, Try this:
    its working thank you
  • bryanpoints
    replied
    boss you're the best ehehehehhehe
  • larrydc
    replied
    [QUOTE=rioreno;723476]this is for your bios...
    extracted from b0cna0ww.exe
    thanks man run ok, one a question how do you do fo extracted b0cna0ww.exe? thanks again.
  • djiaijoe
    replied
    Originally posted by Rashid36
    Bro mcplslg123 could you please show or tell us where to find and connect on SIO, please help us out........ waiting
    Same problem here ...
    Did you find the SIO pin?
    Could you send me the picture of it?
  • exzel
    replied
    thanks
  • Recycler
    replied
    Hi Romulo,
    I've just bought a TL866 plus programmer and today a client brought a broken Lenovo G40-80.
    It turned out the bios was bad.
    I used your bios file that you posted here and the notebook now works again.
    So you helped me with that file, and it's also the first notebook ever that I could repair by desoldering the bios, programming it and soldering it back.
    I had never done that before because I didn't have a programmer.
    Thanks!
  • byrlopez
    replied
    thanks
  • uvaiz
    replied
    thanks,,working
  • Rashid36
    replied
  • Romulo
    replied
    Finally solved the problem i flashed back from the original bios back up file and the find sio pin short to 3.3v power switch and test the laptop on without cmos works fine and put back cmos battery works fine and test for hours now wrking fine thanks everyone for the help
  • rioreno
    replied
    Originally posted by Romulo
    can someone please help i have attached the original bios can someone please fix this i need this urgent please. original is working the only problem is i need to remove and put back the cmos battery i order to turn on.
  • Romulo
    replied
    Please
  • Romulo
    replied
    Please help
  • Romulo
    replied
    thanks for the response mcplslg123 could you please show me where to find and connect this switch?I have attached the full image of the board. please help me
  • meritosari
    replied
    Romulo, try and find the switching pin on SIO. Just connect that pin from SIO to power switch. It will resolve your case. This is not a bios issue.
    Agree with mcplssg123, check on power button (swicth on/off) should be 3.3V have been present. After pressing it become 0V and back to 3.3V.
  • mcplslg123
    replied
  • Romulo
    replied
  • Romulo
    replied
    meritosari ill flash the chip with your bios file laptop turn on and shuts off. while original bios dump file the problem is only i need to remove the cmos battery everytime to start the laptop.
  • lucaszmn
    by lucaszmn
    Problem:
    Initial Findings:
    • I concluded that the
    08-12-2025, 03:01 PM
  • Wahaz
    by Wahaz
    10-30-2023, 08:42 PM
  • gestalt.exe
    Lenovo Legion Y540 – Need help repairing BIOS after bad downgrade
    by gestalt.exe
    My Lenovo Legion Y540 (i7-9750H, RTX 2060) bricked after I downgraded from BHCN44WW to BHCN21WW.
    Laptop stopped booting entirely.
    I used a CH341A programmer to dump the corrupted 16MB BIOS.
    i then attempted the following:
    1. Downloaded stock BIOS BHCN39WW from Lenovo
    2. Trimmed it to 16MB
    3. Extracted the BIOS region from the corrupted dump
    4. Extracted the BIOS region from the stock 39WW
    5. Replaced the corrupted BIOS region with the stock one (within hxd , opened the corrupted dump and replaced its region by the stock)
    6. Injected back my LDGB / DMI
    11-30-2025, 10:38 AM
  • grimacelord
    Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
    by grimacelord
    Hello there.
    I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
    History:
    1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
    I searched for this error online and discovered...
    03-15-2023, 03:29 PM
  • to5it0
    Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
    by to5it0
    Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
    I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
    This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
    I have opened the laptop and identified the main BIOS chip...
    10-24-2025, 01:35 AM
