SONY VGN Z11VN bios needed please
Re: SONY VGN Z11VN bios needed please
Ok rioreno I compare the my old bios which is at the right side in the picture and the [0]file at the left.so I'm seeing some VSS store in my locked bios which is not in the update bios.is that comparison correct?if yes what to do next to get the bios without the password?Comment
1. At [0] file use hexeditor to cut all padding...with help uefitool to gain size and offset..
2. At old bios file extract padding only.
3. With hexeditor again you merger padding from old bios file and rest of [0] file(after cut allpadding)...for the structure refer to your old bios...
Now you get your new file without password...
check this link...
https://www.badcaps.net/forum/showpo...19&postcount=6Comment
no... only 2 padding, 1st and last padding,
why? refer to your old bios.. 1st padding [0] different size with old bios.. last padding not in the list in the old bios..Comment
Please rioreno,when you said in post #25 ,that i should merge the padding file from old bios and the rest of [0] file after cutting paddings, is that mean I should put the rest of [0] file at the end of padding from old bios in hex editor?
If it's so,I'm not getting even the size with old bios.Comment
i said only 1st paddng and last padding, dont touch others padding.. post #33Please rioreno,when you said in post #25 ,that i should merge the padding file from old bios and the rest of [0] file after cutting paddings, is that mean I should put the rest of [0] file at the end of padding from old bios in hex editor?
by DynaxSCHi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...11-17-2023, 10:56 AM -
I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...-
Channel: BIOS Requests ONLY!
by vinaypundithI have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
So, I'm looking for a BIOS dump for this machine - a 16MB one....-
I badly need bios dump for HP DM1-4000er,
Model: HP DM1-4000er
Motherboard: DA0NM9MB6D0 REV.D
Product: QJ490EA#ACB
Please help. My bios chip burned so I don't have the old bios anymore. I need bios dump before I can install the replacement.-
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
- Loading...
