NEED hp 15-p207 DUMO
  • bachir2004
    • Feb 2015
    • 437
    • maroc
    Got hp 15-p207nz.All voltages seem ok.3.3 at power botton.when I press it connector light blinks 3 times and then nothing.Anyone please with a known working dump;especially ec:128kb.here I attach my dumps ec and main.motherboard code is: DAY12EMB6C0 REV:C.
  • bachir2004
    • Feb 2015
    • 437
    • maroc
    Re: NEED hp 15-p207 DUMO
    Anyone please.....
    • bachir2004
      • Feb 2015
      • 437
      • maroc
      Originally posted by bachir2004
      anyone please.....
      problem solved.was charger problem but weird thing first charger is guenine working
      for hp pavillon 15 second one also.both are guenine 19v 4.62a.still cannot undrestand how.the dump is ok.
      • eltipo
        • Oct 2018
        • Argentina
        HP Pavilion - 15-p150nr BIOS day12emb6c0
        HP 17f175n DAY12EMB6C
        • HABIBOU11
          • Jul 2015
          • 50
          • ALGERIA
          Thank you
          Хвала Аллаху, Господу миров
          • Biruslapio
            Panasonic P58V11B 8 and 12 blinks error "fix"
            by Biruslapio
            Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
            Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
            04-13-2021, 07:13 AM
          • Andre Gilbert
            by Andre Gilbert
            11-20-2024, 08:52 PM
          • Taurus12
            Optiplex 3050 micro 2 blinks followed by 3 blinks issue
            by Taurus12
            Does anyone have an idea of what might be the issue with my 3050 micro? I have tried replacing new cmos battery but still the same
            I am not sure if its the powersupply that I'm using is the issue since its the original powersupply. its a laptop powersupply with the same specifications with the 3050 micro so i guess it should be fine.
            i also tried replacing the bios but with no avail, everytime i try another bios it gives a different blinking lights
            Any recommendation on what I have to do next? Thanks in advance
            06-10-2025, 05:05 PM
          • jchon
            Sony A1e 5-blinks help
            by jchon
            Hi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
            I found the service manual, which was critical to know where to probe.
            https://www.manualslib.com/manual/20...1e-Series.html
            With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
            Unfortunately the 5-blinks...
            06-28-2023, 11:52 AM
            HP Clean VSS2 dumps,fix Endpoint Security error
            by SMDFlea
            Just a thread to post clean VSS2 files/dumps in.A clean VSS2 file can, in some cases, fix
            the infamous **"Endpoint Security" error message.
            Be aware that if you use a clean VSS2 you may need to fill in missing DMI info using HP BCU !
            I`ve included some clean files/dumps,offsets and a few scripts to autopatch a few models.
            The offsets and file sizes are part of the naming convention i`ve used for the extracted
            files.
            hoaca388 has made an excellent guide how to extract the VSS2 file and edit/clean it up by
            filling everything after...
            08-08-2024, 03:14 PM
