HP 840 G2 bios error WARNING MACHINE IS NOT IN COMMITTED S
  • jasko_jacker
    • Oct 2014
    • 1140
    • italy
    after I have changed the bios and ME on HP 840 G2 appears this error:
    WARNING MACHINE IS NOT IN COMMITTED STATE
    I think the goal is to change the serial number and others info, correct ? but I lost the utility to make this change.
    Someone have it or know another method to solve this error ?
    Furthermore, the system takes a long time before the screen turns on and initialize the machine.
    The reason is the search for the serial?
    thanks
  • bluestone
    • Jun 2011
    • 343
    • Ghana
    Re: HP bios error
    if you have a backup of your old bios, send both the backup and the new one. I will correct it for you
    • rioreno
      • Feb 2009
      • 540
      • Indonesia
      Re: HP bios error
      thanks
      try this dmifittools is included...
      https://www.badcaps.net/forum/showpo...2&postcount=11
      • jasko_jacker
        • Oct 2014
        • 1140
        • italy
        Re: HP bios error
        I try to use the tool but unfortunately, MPM is not open,if the bios of hp 820 g2 is equal to 840 g2 , I could use the open bios present in the attachment. If it is different, I do not understand the wndmifit message: "MPM is not unlocked. Will not be able to set BIOS settings. Please escalate with UUID to get SMC blob to unlock MPM"
        I have tryed with FSMC changed in SMC with no luck
        • rioreno
          • Feb 2009
          • 540
          • Indonesia
          Re: HP bios error
          use this dump file... after finish you can change dmi id using wndmifit...
          goodluck
          • jasko_jacker
            • Oct 2014
            • 1140
            • italy
            Re: HP bios error
            No luck, the problem is on UUID , to unlock MPM the UUID must be composed of all F.
            I noticed that UUID do not change if I reprogram the bios. I think that the UUID is placed in EC memory that is not in bios.
            • jasko_jacker
              • Oct 2014
              • 1140
              • italy
              Re: HP bios error
              Finally I solve only the machine is not in committed state issue, the goal is:
              if the ec firmware is on separate chip, we need to reprogramm the ec memory and bios with a dump from the same motherboard.
              Remain to solve how change the UUID on ec to all FF if you want to change serial and other info. Maybe it's possible with hex editor but at the owner not interest the change.
              thanks for help
              • angel-boy
                • 550
                Re: HP bios error
                I have the same problem , how can i solve this ?
                • jasko_jacker
                  • Oct 2014
                  • 1140
                  • italy
                  Re: HP bios error
                  As I explain , if the software soluzione fails, you should reprogramm the ec and bios with programmer. Both firmware dump must be taken from the same machine.
                  • angel-boy
                    • 550
                    Re: HP bios error
                    Should be a way to EDIT UUID ,
                    • jasko_jacker
                      • Oct 2014
                      • 1140
                      • italy
                      Re: HP bios error
                      Only after you have solved the issue
                      • Mazzif-Rezzurected
                        • Jan 2015
                        • Any
                        Re: HP bios error
                        Changing FSMC to SMC.bin isnt going to work. Much like the keys created for 1st and 2nd gen HP notebooks, the file created unique to each laptop. It has a time out that only allows for 10 uses, and is also only valid for 10 days after creation.
                        An HP tech would normally use a web based form (on their internal network) to input the required details (Serial, UUID, etc) and it would kick back the SMC file that they would then email to you. Anyways... since you dont have this resource available.
                        So what you need to is reset your UUID to FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                        Once you do this, MPM (Manufacturing Programming Mode) is unlocked and you can run wndmifit to reprogram.
                        A new UUID is created on reboot.
                        Oh I know what your thinking...mazzif...how do we do this?!?!?!
                        I want to tell you I do...but alas...I'm Banned..for Life.
                        • Daudi83
                          • Dec 2018
                          • 66
                          • Hungary
                          Re: HP bios error
                          Is there any way to reset the UUID without resoldering the Chips again?
                          • zhang
                            • Jun 2017
                            • 50
                            • Indonesia
                            Hi bluestone,
                            could you show me the way to edit the bios?
                            Thank you
                            • goldsink478
                              • Feb 2013
                              • 16
                              • indonesia
                              Re: HP bios error
                              upload your bios please
                              • OmegaPrime
                                • Jun 2020
                                • 22
                                Re: HP bios error
                                System Board CT Number usualy is under RAM memory on white or orange sticker (14 characters) .IF cant commit after moding bios , just put back intel ME , if ME is not compatible with model cannot be commited , if you want to remove password just ask.
                                • Ginjaninja
                                  Recovered 850 G1 Bios now the warning machine not in committed state
                                  by Ginjaninja
                                  Hi all just wondering if anyone can help?
                                  i have just recovered my bios after i screwed it up after trying to take a dump of my bios with a clip and a programmer to get around the bios password on one of my old work laptops (HP Elitebook 850 G1).
                                  since the recovery i have been left with the PC now booting up but now i get the warning the machine is not in a commited state and the laptop swithes itself of after about 30 minutes, which i believe is to do with a missing intel management engine.
                                  if anyone can shed any light on wither of these problems,...
                                  05-30-2023, 02:48 PM
                                  by Vesko356
                                  08-11-2023, 03:27 AM
                                • greg.chalk
                                  Asus strix b660-i itx, bios unlock, FPT Error 167: Protected Range Registers
                                  by greg.chalk
                                  I updated my pc, from Evga z270 itx to Asus b660-i itx motherboard. In my old z270 motherboard everything whas easy because everything in bios was unlocked (fd, me etc), and could do everything I want.
                                  Now in my Asus b660 everything is locked (except main bios region). I dont mind so much but I want to unlock bios so I can flash a new splash screen (I have done it with my old motherboard).
                                  I made a bios dump with FPT (fptw64 -d mod.rom -bios), I modded it and I tried to flash back
                                  (fptw64 -f mod.rom -bios). I got Error 167: Protected Range Registers are currently...
                                  10-02-2022, 10:54 PM
                                • jbonavita
                                  by jbonavita
                                  Some issues
                                  Things I tried
                                  04-29-2025, 09:38 PM
                                • zenius
                                  by zenius
                                  12-08-2024, 06:13 AM
