Asus K93SM PBL80 LA-7441P Bios+KBC dump please
  • RethoricalCheese
    • Mar 2013
    • 1518
    • Estonia
    K93SM Bios + KBC dump needed.
    So I received an Asus K93SM (X93S) laptop with a faulty power connector. Fixed that but it still did not turn on. Just the power LED lights up, fan spins up for a few second and thats about it. So naturally I suspected BIOS. Downloaded v204 BIOS from Asus site, flashed it, but still the same. So I suspect it's KBC that needs a reflash. It is a MX 25L1005A chip on it.
    K93SM (X93S) PBL80 LA-7441P v2.0
  • RethoricalCheese
    • Mar 2013
    • 1518
    • Estonia
    Re: Asus K93SM PBL80 LA-7441P Bios+KBC dump please
    Did a lot of googling, meanwhile learned to speak polish fluently Anyway, I found the stuff I was looking for and it did the job. Will post the files as soon as I boot up my laptop again.
    • RethoricalCheese
      • Mar 2013
      • 1518
      • Estonia
      Here they are
      • RethoricalCheese
        • Mar 2013
        • 1518
        • Estonia
        Oh and I forgot to add. When you use this bios on SM version, download K93SM bios from asus website, go to bios and reflash again. Otherwise might not get GPU, audio etc to work in windows.
        • chello
          • Apr 2015
          • Czech Republic
          Hello, this file not work for me, not work corectly battery charge, can not install GPU and audio. Problem with Nvidia GPU and audio resolved after flash in BIOS setup. But still did not work charging when is laptop turned on.
          There is solution !!!
          You do not need dump bios, suffice file from asus website. File K93SM-AS.208 , total size 2176kb-include EC file 128kb and BIOS 4096kb. We will use a hex editor. In hex file a look on line 200000-21FFFFh. We now copy line to a new file and we have an EC file. Now be careful. We have a surplus 0-1FFFFFh line. This is size 2048KB, but We need for BIOS 4096KB. We create new file (BIOS file) with 0-1FFFFFh line, everywhere must be value FF. Now I copy surplus on the position 200000-3FFFFF and done. Note that the file has 4096KB and of which 0-1FFFFFh has a value of FF. This part is not relevant to us and the computer can use it in the future.
          • kiraro
            • Jan 2016
            • 177
            • North NY
            we can apply this method to another asus model ? , i have a problem with asus x555ld rev2.0, nvidia and audio not detected , i tried many bios but same problem,when try to update via usb (easy flash option in bios) it say failed communication protocal or samething like that it may be IO problem also ? .thank you
            • sopik78
              • Nov 2013
              • 517
              • Czech Republic
              Anybody can share BIOS + EC dump for Asus X93SM PBL80 LA-7441P?
              Thanks!
              • sopik78
                • Nov 2013
                • 517
                • Czech Republic
                Come on guys, nobody can help?
                • sopik78
                  • Nov 2013
                  • 517
                  • Czech Republic
                  Still in trouble with the bios..
                  • sopik78
                    • Nov 2013
                    • 517
                    • Czech Republic
                    Up
                    • cacla
                      • Apr 2015
                      • 442
                      Pls give me the serial number for your model
                      • casti3l
                        • Mar 2014
                        • 95
                        • romania
                        HERE you have a lot of bin, ec and main, in archive you will find also both bin's that i tested, and schematic
                        X93s
                        K93s
                        Schematic also
                        • kcp0085
                          Request BIOS dump for ASUS FA617NS-A16.R77600
                          by kcp0085
                          Aloha, I'm trying to recover my ASUS TUF Gaming A16 (FA617NS-A16.R77600)
                          I have the CH341A programmer and can flash the BIOS chip directly. I need a verified full .bin dump (2MB or full SPI region) for this specific model.
                          Specs:
                          - ASUS TUF FA617NS-A16
                          - CPU: AMD Ryzen 7
                          - BIOS chip: Winbond W25Q16JVSIQ (2MB)
                          If anyone has a full dump or can share from a working unit, it would be hugely appreciated.
                          Thanks in advance!​
                          05-02-2025, 12:52 AM
                        • Tamo Neko
                          Request for MX25VB8035F (1MB) Firmware Dump – Asus TUF Gaming H670-Pro
                          by Tamo Neko
                          I'm working on an Asus TUF Gaming H670-Pro motherboard and need help finding a firmware dump for the MX25VB8035F (1MB) SPI flash chip.
                          What Happened:
                          I mistakenly removed and erased this 1MB chip, thinking it was part of the main BIOS.
                          • I later found that the board has two main BIOS chips (8MB + 16MB), which I have backups for.
                          • My backup for the MX25VB8035F chip is just an empty 1MB segment filled with FFs, meaning I have no valid data to restore.
                          What I Need:
                          • A firmware dump for the MX25VB8035F chip from the same motherboard (or a compatible
                          02-12-2025, 11:29 PM
                        • Anchar777
                          ASUS P1412CE need BIOS DUMP
                          by Anchar777
                          Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
                          06-26-2025, 03:39 AM
                          ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook CX1 Specification for Upgrade or Repair
                          This specification for the ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB boardview and ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...
                          09-07-2024, 02:50 AM
                          ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook Specification for Upgrade or Repair
                          This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
