Msi cr420 bios needed
  • String2016
    • Nov 2015
    • 2234
    • philippines
    Hi everyone please help!I need a working bios dump file for MSI CR420. thanks in advance
  • String2016
    • Nov 2015
    • 2234
    • philippines
    Re: Msi cr420 bios needed
    Anyone please help
    • rioreno
      • Feb 2009
      • 540
      • Indonesia
      Originally posted by String2016
      Anyone please help
      try, and please confirm working or not
      • String2016
        • Nov 2015
        • 2234
        • philippines
        Ok thanks Ill try this
        • String2016
          • Nov 2015
          • 2234
          • philippines
          bios above working thanks for the file sir rioreno laptop now working I change the nec tokin caps to 4 330uf tantalum caps and then flash the bios chip with your file laptop now working fine thanks again
          • String2016
            • Nov 2015
            • 2234
            • philippines
            update: after 1hour of testing when I Shut down the laptop after a couple of minutes when I turn it back on turn on but no display I notice fan spinning very fast then shuts off then turn a second again but the led light still present no display. I have attached the original bios bin file can someone fix this or clear me. Thanks in advance
            • String2016
              • Nov 2015
              • 2234
              • philippines
              Anyone please help
              • String2016
                • Nov 2015
                • 2234
                • philippines
                Please help
                • String2016
                  • Nov 2015
                  • 2234
                  • philippines
                  Anyone please help
                  • String2016
                    • Nov 2015
                    • 2234
                    • philippines
                    Ive change the bios chip and flash again with the file above it works but I have one problem there is no back light on the screen but when i plugged in hdmi cable display is ok . Ill tried changing the screen still there is no back light.Ive found a fuse near lvds connector its 330 .should i remove this fuse?Please help me.I had attached the image of the board and the fuse near the lvds
                    • llorente
                      • Apr 2020
                      • Colombia
                      Thank you very much for the Bios file
