Apple Macbook Pro A1278 BIOS Dump
  • raajkumar
    • Mar 2015
    • 354
    • Srilanka
    Hi, I need Bios Dump for A1278, 820-2565-A and the EMC number is :2555
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: Apple Macbook Pro A1278 BIOS Dump
    if you have password problem, read bios with password and post it here
    Im Back... sort of...
    • raajkumar
      • Mar 2015
      • 354
      • Srilanka
      at the moment its bios has corrupted. So i need a working and full functional bios dump.
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        make backup and good luck
        MacBook Pro Core i5 2.4 13 Late 2011 emc 2555
        • raajkumar
          • Mar 2015
          • 354
          • Srilanka
          Thank you. I will Update with it.
          • raajkumar
            • Mar 2015
            • 354
            • Srilanka
            Sorry for late reply. Because today only i received my programmer. I reflash it with Ala_Borbe's file. But It is not working it still not powering up. All voltages are correct is there anyone having any idea.
            • lalit86.modh@gmail.com
              • Apr 2016
              • india
              apple a1278 820-2565-a bios pls
              • rafik_40150
                • Dec 2016
                • 22
                • algeria
                hello
                is it working with
                macbook pro A1278 820-2565-A EMC 2351 ???
                • drmak
                  • Jun 2017
                  • 3
                  • St Vincent
                  I have a similar Mac-book with password problem it's a 820-2565-A EMC 2351
                  This is the old dump file I pulled from the bios chip. I need to replace it will a clean bios file so the system can work. Is there anyway this can be cleaned thank you.
                  • ala_borbe
                    aka Donald
                    • 1625
                    • Malta
                    this will work on your model
                    Code:
                    https://itcrush.wordpress.com/2012/04/14/how-to-bypass-apples-efi-password/
                    • drmak
                      • Jun 2017
                      • 3
                      • St Vincent
                      Thank you so much, it actually worked i'm very happy and grateful for your help you're a genius.
                      • nimmay
                        • Dec 2015
                        • 82
                        • Pakistan
                        Hi, I need Bios Dump for A1278, 820-2565-A and the EMC number is :2419
                        • thangaraj.gk
                          • Apr 2019
                          • 5
                          • INDIA
                          I HAD UPLOADED THE BIOS DUMP WITH PASSWORD KINDLY DO PROCEED
                          MacBook Pro "Core i5" 2.4 13" Late 2011
                          • ala_borbe
                            aka Donald
                            • 1625
                            • Malta
                            here you go
                            • thangaraj.gk
                              • Apr 2019
                              • 5
                              • INDIA
                              here you go
                              thanks dude
                              • thangaraj.gk
                                • Apr 2019
                                • 5
                                • INDIA
                                [QUOTE=ala_borbe;894035]here you go[/QUOTE
                                After up dating this bios the mac wont's turn on please any idea ?
                                • peste
                                  • Dec 2016
                                  • 12941
                                  • ROMANIA
                                  Try this one
                                  • thangaraj.gk
                                    • Apr 2019
                                    • 5
                                    • INDIA
                                    Originally posted by peste
                                    Try this one
                                    THANKS A LOT IT WORKED FOR ME
                                    • thangaraj.gk
                                      • Apr 2019
                                      • 5
                                      • INDIA
                                      Originally posted by thangaraj.gk
                                      thanks dude
                                      on the ame device led blinking problem on bios do help me
                                      • BLAHA
                                        • May 2020
                                        • Polska
                                        Pass: CAROLINA
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • haitham sharabati
                                          [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                          by haitham sharabati
                                          Hello engineers 😀,
                                          I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                          🔧 Device Info:
                                          - Model: HP 15-da2007ne
                                          - Product Number: 8XF55EA#ABV
                                          - Serial Number: CND0338P0D
                                          - CPU: Intel Celeron N4000
                                          - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                          💀 Problem:😅
                                          - Device shows “Administrator Password”...
                                          08-07-2025, 04:54 AM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
