Toshiba A300 188 bios password.
    Hi.
    I have a Toshiba A300-188 with bios password.
    Is there any way to remove it?
    Thanks...
    Re: Toshiba A300 188 bios password.
    zord_z yes there is and its quiet easy ,
    first remove battery and dc power , and open memory tray
    now with the memory tray removed , you will noticed a jumper with 2 solder points under the ram module (on the board) you must solder a wire between the 2 points , insert memory again , and nisert dc power and turn on , it will take a bit longer to show up image , but it will turn on and password is removed , after been removed , disconnect computer , remove the bypass you've made and enjoy
    chek the link to see the bypass point
    http://webpcmag.com/wp-content/uploa...d2-300x220.jpg
      Thank's highpulse!!
        With 2 points soldered , the laptop doesn't powers up... Now I have to remove bios and flash it with my programmer
