Need bios dump for Elitebook 850 G3
    Re: Need bios dump for Elitebook 850 G3
    Originally posted by drobino View Post
    Hello guys, i was try unlock my bios on HP 850 g3 with soft hpunlocker unfortinatelly now is laptop dead only light on power botton blink then nothink will happen (0AMP drawing). status led blinking 4times white and amber then stop. I was try original bin but doesn't work either. I was check soldering many times nothing looks bad. Can someone check my original bios? Thank you very much
    Try me clean file from your original backup ...
    Good luck ...
      Good luck ...
      Thank you unfortunately doesn´t work. Still the same thing, probably EC firmware goes wrong? I have 3.3V on pin 8 and 1 on bios chip only 1sec after I plug in the charger. No reaction on power botton. Have HP 850 writen EC in bios?
        Hi, could someone take another look at my bin files? Laptop completely unresponsive after removing the bios password, zero Amp consumption. on pin 1,2,5 and 6 clk of both chips i can see communication on the oscilloscope for a short time after applying power but that's it. What I tried:
        I cleaned the ME region, Compiled a new clean bios from the HP site, checked several times the soldering around the bios chips,
        I also replaced the EC npce586 itself but no change. If anyone has any ideas I would be very grateful thank you
          need bios for my laptop hp elitebook 850 g3
          motherboard number 6050a2892401-mb-a01
          cpu i7
          SN# 5CG6464FK9
            Please try and report
              Hi i need fix bin 850g3
              The backlight works without data
              Caps look 1 error lamp
              6050A2892401-MB-A01
              i5-6300U
                6050A2892401-MB-A01
                i5-6300U
                Serial number ?
                Become a Badcaps supporter
                Thanks to all supporters.
                  I don't know, his book is not available
                    The serial number is on the bottom of the laptop : 5CG7221438
                    • seifaldenn
                      seifaldenn commented
                      Editing a comment
                      Thank you, it works and the latest version ❤️🩹
                    • seifaldenn
                      Editing a comment
                      The device freezes and restarts when entering USB to download a new version
                    With the appearance of a blue screen when entering Windows or Windows Mini USB or Restart, I changed the RAM as well.
                    • seifaldenn
                      Editing a comment
                      I connected to the Internet trying to update the Bios from Bois. It was updated to 1.60 and the same problem
                    Hi, could you please help me unlock my Elitebook 850 G3
                    SN#5CG73613R9
                    Regards​
                      SN#5CG73613R9
                      Regards​
                      Unlocked
                        It works fine, thank you
                          Hp 850 g3 , lost original bios file can anyone help with a clean bios ? Thanks
                          serial number
                          SN 5CG7060865
                            Hi I need bios for hp 850 g3
                            backlight and capslock blink with no display
                            SN 5cg8334b5s
                            hello. i have this hp elitebook 850 g3 ,
                            sn: 5CG82809DL
                            mb: 6050A2892401-mb a01
                            when i power it on no display and fan at max, maybe it need me cleaning, i tried different dumps but no result .
                              SMDFlea commented
                              Editing a comment
                              post moved from 840 G3 thread topic to 850 G3
                            sn: 5CG82809DL
                            HP EliteBook 850 G3 Base Model Notebook PC
                              Help bios password Hp Elitebook 850 G3
                              sn: 5cg63934bk
                              Attached bios
                                sn: 5cg63934bk
                                Attached bios
                                Read the password guides, try to unlock it yourself using RCUnlocker - https://www.badcaps.net/forum/troubl...rces-and-tools
                                  Will RCUnlocker work on Hp Elitebook 850 G3
                                  if yes then i need RCUnlocker. anyone can upload pls.
