Sony Vaio PCG-71213M bios dump plz
  • medinfo
    • May 2016
    • 328
    • Morocco
    Re: Sony Vaio PCG-71213M bios dump plz
    merci khoya je vais esseyé, en tous cas tu es de casa et moi de oujda, on peut faire des rechange de bios ou n'importe quoi, je suis technicien en informatique et je pense que c'est ton domaine aussi .
    • medinfo
      • May 2016
      • 328
      • Morocco
      même chose khoya, mais j'ai réparer le problème j'ai changé une parti du fichier.bin qui contiens le mot de passe, merci beaucoup pour votre aide .
      • cyberhack
        • Feb 2013
        • 466
        • Uk
        English please so we can flow the posts
        • cyberhack
          • Feb 2013
          • 466
          • Uk
          [QUOTE=cyberhack;678047]English please so we can follow the posts that would be helpful.
          • ridamouh159
            • Nov 2014
            • 365
            • maroc
            [QUOTE=cyberhack;678235]
            I have say that this laptop it coming to me for some days with display and working good but the problem is after some
            minutes stoped -ie is overheating and shutting down-
            the heatsink was blocked with lint.
            naturaly for always i take a copy for the bios to all the laptop coming with problem to me
            and he wanted that we can helping us -exchange bios....idee because we are from morroco and not far .......
            • medinfo
              • May 2016
              • 328
              • Morocco
              #26
              Ok thank you
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16956
                english only. I will remove all non-english posts.
                <--- Badcaps.net Founder
                Badcaps.net Services:
                Motherboard Repair Services
                http://folding.stanford.edu/
                Team : 49813
                Join in!!
                Team Stats
                • SanWilliams
                  • Jun 2016
                  • 15
                  • peru
                  #28
                  Re: Sony Vaio PCG-71211M bios dump plz
                  bios dump
                  • sommek
                    • Jan 2017
                    • greece
                    #29
                    Hi , i have the same sony vaio PCG-71213M (vpceb4j1e).which utility did you use to update your bios with the attached file ridamouh159 has sent you?I think i have a corrupted bios and i really need to reinstall my bios
                    • lefos
                      • Nov 2013
                      • 321
                      • Greece
                      #30
                      Hello sommek, you have to remove the bios chip from the board and reprogram it using an external programmer.
                      • sn4k3
                        • Oct 2016
                        • 68
                        • Portugal
                        #31
                        Originally posted by SanWilliams
                        espero que te sirva saludos
                        Thank you.
                        This is what i need too
                        Regards
                        • mc1255
                          • Apr 2017
                          • algerie
                          #32
                          Bjr everyone.
                          Here is my sony vaio pcg-71211 whose card was hs i bought another motherboard pcg-71213, the problem now is that my sony will only start if the battery is lodged and the charger is stuck.
                          It does not start with the charger alone or with the battery alone.j wanted to flash the bios but I do not find the flash software under dos thank you for your help
                          • jdidi
                            • Sep 2016
                            • 7
                            • el jadida
                            #33
                            thank you
                            • ABDELKADER
                              • Nov 2017
                              • 9
                              • MAROC
                              #34
                              It works with sony vaio PCG-71213M[ VPCEB3E1E] thank you
                              • bidawisoft
                                • Nov 2016
                                • 17
                                • morocco
                                #35
                                Thank you.
                                • Qalib
                                  • Jun 2016
                                  • 9
                                  • Mingechaur
                                  #36
                                  Assalamun Aleykum. Thanks you and all the developer of this site.I am very helped by this site.
                                  • mahmoodjavan
                                    Banned
                                    • Mar 2018
                                    • 584
                                    • iran
                                    #37
                                    sony vaio PCG-71211M VPCEB1Z0E mbx-224 M961 MP MB RVE1.1 Bios + EC
                                    • toufik sat
                                      • Feb 2016
                                      • 134
                                      • los angles
                                      #38
                                      Ok thank you
                                      • panaitepaul
                                        • Jan 2020
                                        • 11
                                        • România
                                        #39
                                        Originally posted by mc1255
                                        Bjr everyone.
                                        Regarding the same problem, for a Samsung laptop, I needed to change a capacitor behind the microprocessor. If I remember correctly, the latop would only start if I removed the charger and it would only work on battery.
                                        • JIMBOYVOLTRON
                                          • Dec 2020
                                          • 5
                                          • philippines
                                          #40
                                          Re: sony vaio PCG-71211M VPCEB1Z0E mbx-224 M961 MP MB RVE1.1 Bios + EC
                                          Tnx tested ec bios ok
                                            Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                            This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-06-2024, 05:27 AM
                                          • nope69
                                            SONY VAIO SVE14135CXP BIOS dump & help request
                                            by nope69
                                            BIOS VERSION: R0200D5
                                            ME VERSION: UnKnown
                                            Background:
                                            I have a SONY VAIO SVE14135CXP that appears to have a missing ME Region firmware.
                                            The symptom is that the machine boots, but shuts down 30 minutes later.
                                            I have the similar issue that another user has, just a different model of sony vaio.
                                            https://www.badcaps.net/forum/showthread.php?t=103305
                                            What I have done:
                                            I have purchased the CH341A programmer clip and did the 3.3v mod.
                                            I have successfully...
                                            06-28-2022, 10:09 AM
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • haitham sharabati
                                            [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                            by haitham sharabati
                                            Hello engineers 😀,
                                            I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                            🔧 Device Info:
                                            - Model: HP 15-da2007ne
                                            - Product Number: 8XF55EA#ABV
                                            - Serial Number: CND0338P0D
                                            - CPU: Intel Celeron N4000
                                            - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                            💀 Problem:😅
                                            - Device shows “Administrator Password”...
                                            Yesterday, 04:54 AM
                                          • mariukonie
                                            SONY VAIO PCG-711911M VPCEH2H1E advice about updating BIOS to UEFI needed please!
                                            by mariukonie
                                            Hi. I can't upgrade to win11 I think it's because my BIOS is without Secure Boot function. The BIOS version is R0180Z9. Can you please advise if it is possible to upgrade BIOS to UEFI for this laptop. Many thanks....
                                            05-04-2025, 03:18 PM
