Please I need a working bios dump compatible for Dell M4600 , thank you !
Need Bios dump for Dell M4600
Re: Need Bios dump for Dell M4600
hi this fixed my bricked dell tahnk you all
now at bios 04 is there any major reasons to upgrade
I would hate to take the whole laptop apart to be able to reflash my bios (last night it was ok, but I would prefer not to have to do it again)Comment
last is A19 but on .exe file..
can you tell me bios version of attached dumped file.Comment
could you tell what were you facing.? am facing freeze at dell logo afte blue bar fills all the way. then freezes .. pressing F12 does nothing. have programer ch34a1 but havent flash as the clamp got damaged afte ive read the chips.
https://www.youtube.com/watch?v=DWWigscuQDYDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
do not use the clip because it gives errors..remove the bios chip from the motherboard before writing or reading, paste the chip on the programmer, or use the bios chip adapter ... make a copy of the contents of the bios chip and post ...
i had to take it to a repair shop. but need to find one as where i live there arent man repair shops. i live in small town.Comment
solved thanks guys.
my laptop after installing win 10 by usb when it finished copying all the ffiles and it restarts to set up pc and take you to desktop.. but mine after restart got frozen at dell logo. pressing any key did nothing.
using provided dump i was aable to enter bios and to windows using a programmer ch43a1
the version of dumped bios is A04Comment
could not find the edit button.
update
i got it working but now am facing a problem with win 10. not sure if the dump the flashing or the 2 micro resistor i accidentally removed cause this but clean install of windows 10 i t goes smoothly. if restart all ok. but if i shut down the laptop and when turn on it freezes at the windows 10 logo qith spining dots.
safe mode works fine also if i get to advance recovery after 3 on and off of laptop and repair screen appears if done a restore point after clean install i can restore and all good. can run bench mark on both video cards.
strange if i install win 7 i can shut down and face no problem.. only on window 8,1 10 and 11. all freeze at windows logo spining dots before sign in screen.Comment
by AhariHi all,
I...-
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by jhanraHi there masters, recently i got a dell 5400 chromebook and wanted to install windows, i searched the internet and i found out other people also wanting a UEFI bios for this model, i searched there is a R/W legacy, but there are bugs like keyboard/trackpad not working, and hard to install.
in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...-
Channel: BIOS Requests ONLY!
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
by gizahaDell latitude 5580, motherboard cdp 80 la-e151p
Since ssd is replaced and had clean install windows, i've... - Loading...
