Software to dump Bios
  • passete
    Living=Sharing
    • Jun 2015
    • 487
    • France
    Which software can i use to dump a bios with a working PC ?
  • akarta
    • Nov 2015
    • 16
    • United Kingdom
    Re: Software to dump Bios
    If its not laptop, but PC, some motherboards can be dumped using flashrom under linux.
    That type of bios / motherboard do you have?
    • passete
      Living=Sharing
      • Jun 2015
      • 487
      • France
      I am searching mostly for laptop, with desktop no need desolder on some.
      • sopik78
        • Nov 2013
        • 517
        • Czech Republic
        Try to use attached tool, but AFAIK, it cannot save EC, only main BIOS.
        • Djosla
          • Dec 2012
          • 246
          • Montenegro
          note that it doesn`t work very well for all kind of laptops... dumping with programer is the best way...
          • diif
            • Feb 2014
            • 6978
            • England
            I use the software that comes with the CH341A.
            • passete
              Living=Sharing
              • Jun 2015
              • 487
              • France
              Can you post it ?
              • Djosla
                • Dec 2012
                • 246
                • Montenegro
                it is a software for programmer, it won`t be of any use...
                • passete
                  Living=Sharing
                  • Jun 2015
                  • 487
                  • France
                  This is what i thought, cause i don't see how can you dump using an app for a hardware reader/writer !
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    This is the hardware I use, although the clip I bought had been modified and I put a weaker spring in it. I only use it for chips off the board. The software I downloaded from this forum, I can provide a copy if you want.
                    http://www.ebay.fr/itm/Bios-Board-Mu...sAAOSwoudW~NT-
                    • passete
                      Living=Sharing
                      • Jun 2015
                      • 487
                      • France
                      Thanks Buddy,
                      but i already have a hardware reader/writer and even the same clip.
                      What i am trying to achieve, is to dump/read the bios on a working laptop, without the need of disassemble it.
                      • Ahari
                        by Ahari
                        I...
                        08-13-2025, 06:12 AM
                      • Habble7
                        by Habble7
                        Suspected Cause:
                        Troubleshooting Attempts:
                        05-22-2025, 07:28 AM
                      • haitham sharabati
                        [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                        by haitham sharabati
                        Hello engineers 😀,
                        I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                        🔧 Device Info:
                        - Model: HP 15-da2007ne
                        - Product Number: 8XF55EA#ABV
                        - Serial Number: CND0338P0D
                        - CPU: Intel Celeron N4000
                        - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                        💀 Problem:😅
                        - Device shows “Administrator Password”...
                        08-07-2025, 04:54 AM
                      • Citymin
                        by Citymin
                        S/N : 5RNK9FFT70...
                        08-05-2025, 05:12 AM
                      • DynaxSC
                        by DynaxSC
                        11-17-2023, 10:56 AM
