Dell 5559 bios
Every donation made will go towards server fees and maintenance costs. -
Every donation made will go towards server fees and maintenance costs.Comment
Re: Please Someone Can Clean ME for this Bios?
you think is the BIOS chip? ive flashed the bios a few times trying some ME versions, mine is 11.5.XXXX if i use 11.8 still works but as kalilinux say it happens again, in the otherhand it was running slow even when ive installed a SSD, im guessing this issue can be causes for a BAD pch or CPU... i mean this happens often in macbooks with the same CPU architecture... so maybe we will have near future failing cpu chipsComment
great topic sir that maybe causing my issue thanksyou think is the BIOS chip? ive flashed the bios a few times trying some ME versions, mine is 11.5.XXXX if i use 11.8 still works but as kalilinux say it happens again, in the otherhand it was running slow even when ive installed a SSD, im guessing this issue can be causes for a BAD pch or CPU... i mean this happens often in macbooks with the same CPU architecture... so maybe we will have near future failing cpu chipsComment
Dell 5559 bios need - Core I5
Hi there, can someone please repair this bios file as laptop no power on, consuming .007 amp when pressed power button. Fan does not spin, no led light.Attached FilesComment
Re: Dell 5559 bios need - Core I5
Try
BTW 5999 THREAD IS ALL READY EXIST IN THIS FORUM YOU MAY POST THERE
HOPE MODERATE WILL MOVE THIS THREAD TO DELL 5999Attached FilesComment
Re: Dell 5559 bios
need bios repair urgently
AAL15 LA-D071PComment
Re: Dell 5559 bios
Inspiron 5559
Service Tag: JQLQM72Attached Files↵
https://www.badcaps.net/donateComment
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by capoplaysHey everyone,
I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
When I check the BIOS using the F12 menu Flash...-
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
by SathsulSo, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...-
- Loading...
. Thanks.
