Pls. I need hp quanta R33 bios or dump.
  • banchi99
    • Jul 2015
    • 107
    • U.S.A
    I had tried to find it in diferent site no result. thks in advance.
    regards..
  • ridamouh159
    • Nov 2014
    • 365
    • maroc
    Re: Pls. I need hp quanta R33 bios or dump.
    try it
    if not working put the model name
    • banchi99
      • Jul 2015
      • 107
      • U.S.A
      Hi, Bro. here is the model HP g4 2268la. thks again.
      • ridamouh159
        • Nov 2014
        • 365
        • maroc
        i hope that working for you
        the same bid
        • banchi99
          • Jul 2015
          • 107
          • U.S.A
          Yeap.this is the one. thnks,thnks. again.
          • modbo
            • Jun 2018
            • 7
            • sudan
            thaaaaaaaaaans
            • Habble7
              by Habble7
              Suspected Cause:
              Troubleshooting Attempts:
              05-22-2025, 07:28 AM
            • DynaxSC
              by DynaxSC
              11-17-2023, 10:56 AM
            • grimacelord
              Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
              by grimacelord
              This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
              Motherboard model number: DA0PAMB46A1 REV: A
              Secondary motherboard model number: 0PAB
              SKU: 685K4UA
              Serial number is: 5CD3223BJP
              Recently reflashed this laptop with latest BIOS and once...
              05-07-2024, 08:06 AM
            • DynaxSC
              Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
              by DynaxSC
              I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
              It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
              I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
              11-06-2022, 05:22 PM
            • TacticalFahrrad
              [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
              by TacticalFahrrad
              I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
              06-30-2025, 04:09 AM
