Lenovo G50-30 bios dump needed
  • rizky
    • Jun 2021
    • 7
    • indonesia
    #81
    Re: Lenovo G50-30 bios dump needed
    thanks
    Originally posted by kazia
    my be this your dump, make backup
    • snakepit7
      • Dec 2015
      • 26
      • mexico
      #82
      Thanks you so much!!
      • djharold
        • Aug 2015
        • 247
        • COLOMBIA
        #83
        thanks
        • bonorzs
          • Sep 2021
          • Hungary
          #84
          thanks
          • hipps
            • Sep 2021
            • PL
            #85
            thanks!
            • egelaptop
              • Jun 2015
              • 125
              • türkiye
              #86
              thank you
              • Ngo Thien
                • Feb 2023
                • việt nam
                #87
                Re: Lenovo G40-30 bios file.
                Originally posted by lzrman
                its working dump..
                thank
                  • Jun 2022
                  • 18
                  • Nigeria
                  #88
                  Works 💯
                  • lhans122907
                    • Aug 2018
                    • philippines
                    #89
                    Thank you working
                    • ravikishore
                      • Jan 2020
                      • 8
                      • India
                      #90
                      its working dump..
                      yes it is working perfect
                      • alaminp
                        • Jan 2022
                        • 21
                        • saudi arabia
                        #91
                        Lenovo G50-30 bios work windows 7
                        • Joluvillas
                          Lenovo ThinkPad L15 Gen 1 i7 (20U4) Bios and EC dump needed
                          by Joluvillas
                          Hi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
                          06-18-2024, 10:35 PM
                        • AHmad_Salal
                          Need BIOS Dump/ROM for Lenovo Thinkstation p500
                          by AHmad_Salal
                          Hello all,
                          I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                          11-28-2023, 05:28 AM
                        • DynaxSC
                          by DynaxSC
                          11-17-2023, 10:56 AM
                        • TacticalFahrrad
                          [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                          by TacticalFahrrad
                          I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                          06-30-2025, 04:09 AM
                        • hirens
                          Lenovo ideapad 3 14IGL05 bios dump needed
                          by hirens
                          model: 81wh
                          sn: pf36ta6h
                          board no: nm-c961 gs453/gs553
                          hey guys above is my laptop info
                          it only blinks the power button kindly help me with a working dump
                          old dump attached...
                          07-21-2023, 04:48 AM
