Need a bios dump for Lenovo Thinkpad X1 carbon. thanks
Lenove Thinkapd X1 carbon bios dump
Re: Lenove Thinkapd X1 carbon bios dump
That is another issue but currently the system is complete dead only power led blink three time then nothing and another technician write the bios with wrong file.
i search on google and i found a BIN file for same model but that is 16MB and the eprom is 8MB as i attached below.Attached FilesPremium supporters get full download access and other benefits.
This one may beAttached FilesPremium supporters get full download access and other benefits.
@dycc i write your provided file 8MB the result is now power on^off OK, keyboard lights OK
Function keys touch panel ok but the problem is no display.
i also download another dumps from a Russian forum on that is different symptoms power on that dumps power on ok but shut down after two mints and no display.
i am confused that this board is 8MB or 16MB bios the board complete ID is Lenovo Thinkpad X1 Carbon LMQ-1 MB 12298-2 48.4LY07.021 .Comment
thraj this for lenovo x1 carbon LMQ-1 MB 12298-2 48.4LY06.021Attached FilesPremium supporters get full download access and other benefits.
Hi Working Lenovo x1 carbon 16 mb fileAttached FilesPremium supporters get full download access and other benefits.
I have the lenovo x1 carbon LMQ-1 MB 12298-2 48.4LY06.021 mentioned above.
Can somebody tell me where the BIOS chip is on this!!!
I can see all the IC numbers and the BIOS battery but not the chip itself. Anybody?Comment
It's shameful that even the new generations of the X1 have the same fault.
I found the BIOS chip (mxic 25l6475e) and took it off the board, which was very difficult. The solder would just not melt. So I soldered the points with a soldering iron to help try loosen up the solder. It worked but it was touch and go there for a while.
Read in the old BIOS successfully without any problems, but having problems writing back to the chip with the replacement BIOS. It seems to finish fully but pops up with an error saying "Programming Stopped". gonna try on another workstation in case there are USB issues. Fingers crossed.Comment
bonjour, jai un lenov x1 carbon mot de passe bios, comment le débloqué ? flash bios ne fonctionnera pas car le mot de passe n'est pas stocker dans l'eeprom bios? merci de m'aider
Hello, I have a lenov x1 carbon password bios, how to unlock it? flash bios will not work because the password is not stored in the eeprom bios? thank you for helping meComment
by AhariHi all,
I...-
by JunhijamHi, I'm new to all of this so I hope I'm doing correctly and not breaking any rules.
I need help for my MSI PRO B660M-A DDR4 motherboard BIOS dump.
The motherboard got bricked during BIOS update due to a power cut in my village while updating BIOS. Now the PC is not booting. Fans kept spinning and no display is coming.
A local technician said I need the full BIOS dump/file for this motherboard.
My Motherboard model is:
MS-7D43 REV 1.0
The Bios chip is:
MXIC
MX25U25673GZ4140
Please, if anyone has the same board...-
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
by kinojk2Hi, Thanks for all you do here.
I have attached my 16MB dump.
EDIT2: All hardware working fine, I think I just need to update my linux booatloader and all gucci
EDIT:
I can get into bios now! I reflashed as instructed elsewhere. With a minimal POST (just 1 stick of ram , GPU, CPU, no drives) I have loaded into BIOS. I am about to reinstall my other hardware components now.
The clips are such a pain to use, soldering would be a great skill to have.
Thanks for the advice in other threads!
To answer my own question, I didn't...-
03-24-2026, 05:55 AM -
by repairplusThinkPad X1 Carbon 2020 LTE(20U9007FCD)
1) CPU : I5-10210U
2) RAM : 16GM
3) SSD 512GB
4) FRU: 5B20Z25528
GY4A0/GYG50 NM-C881 Rev 1.0
Symptoms: This is a no-display response symptom after bios update.
Thank you....-
Channel: BIOS Requests ONLY!
- Loading...
