Hi pls lenovo z50-70
  • hoaca388
    Badcaps
    • Jan 2022
    • 12346
    #61
    Re: Hi pls lenovo z50-70
    Originally posted by NTBservis
    I need dump for Lenovo Z50-70 ACLU1/ACLU2 UMA NM-A272 please.
    Bad dump attached.
    Your serial number ?
    • NTBservis
      • Jun 2016
      • 32
      • Czech
      #62
      s/n: YB10552514
      • hoaca388
        Badcaps
        • Jan 2022
        • 12346
        #63
        s/n: YB10552514
        Z50-70 Laptop (Lenovo) - Type 80E7
        • NTBservis
          • Jun 2016
          • 32
          • Czech
          #64
          Working Thank you.
          • 114MAREKR
            • Sep 2022
            • 6
            • polska
            #65
            thanks it work good
            • panaitepaul
              • Jan 2020
              • 11
              • România
              #66
              lenovo z50-70
              s/n YB07914565
              ACLUA/ACLUB NM-A273 REV 1.0
              IT8586E
              It's my laptop. It was powered off properly and did not start again. All sources on the motherboard are fine, but the computer does not start. The power LED is on all the time. I can power off and on again de motherboard from power button. I suppose it's a bios fault. I tried the bios posted here and none of them work.
              I am attaching my backup.
              Thank you in advance.
              • hardware1
                • Sep 2021
                • 2948
                • N/A
                #67
                Originally posted by panaitepaul
                lenovo z50-70
                s/n YB07914565
                IT8586E
                Here's your new bios file, try it and let me know the results.
                all donations are welcome,
                • panaitepaul
                  • Jan 2020
                  • 11
                  • România
                  #68
                  Thank you for such a quick reply.
                  I tried the BIOS modified by you this evening and it doesn't work. However, there are other symptoms: after about 30s, the fan starts and works at maximum speed.
                  I also tried to extract the flash from the BIOS file on the official website (it's different from the one modified by you) and it still doesn't work. More precisely, I extracted the .exe file with 7zip, and then, using HxD, I searched in the isflash.fd file for the beginning of my file. I selected starting from there the 800000 block and saved the file, then I wrote it in memory.
                  Exactly the same symptoms as with the file processed by you.
                  Any idea?
                  This is the file I obtained
                  • hardware1
                    • Sep 2021
                    • 2948
                    • N/A
                    #69
                    Any idea?
                    Our files are the same, the only difference is the device information area because I moved it from the original file.
                    Perhaps you have a hardware issue.
                    • panaitepaul
                      • Jan 2020
                      • 11
                      • România
                      #70
                      It could be but I don't know what else to check. I checked all the sources and they seem to be fine, I disconnected all the components from the motherboard, I tried with another RAM, the processor cannot be replaced with the tools I have. I will probably abandon it. Too bad I've only had it for a month...
                      Thanks for your time!
                      • kamkooltech
                        kamkooltech
                        • Jun 2019
                        • 127
                        • nigeria
                        #71
                        Ok, thanks
                        • wakamelo
                          • Nov 2014
                          • spain
                          #72
                          Re: Lenovo Z50-70 bios neededhi
                          Originally posted by mielta
                          Hi
                          Try This
                          100% work
                          • 11profit
                            • Feb 2023
                            • 36
                            • Poland
                            #73
                            Hello, someone have bios for Lenovo Z50-70 with i5-4210U?
                              VIP Moderator
                              • Aug 2018
                              • 4386
                              • Bulgaria 🇧🇬
                              #74
                              Upload your bios backup, serial number and issue description. Do you have discrete graphics onboard or only integrated Intel gpu?
                              Become a Badcaps supporter
                              Thanks to all supporters.
                              • ianbak
                                • Apr 2023
                                • 59
                                Hi, I have a Lenovo Z50-70 (with Core i7-4510U and Nvidia GT820M) that wouldn't boot. After some investigation, I reflashed the BIOS with one that I downloaded from elsewhere on this site. This got it working again, proving that BIOS corruption was the cause of the original fault. So far so good!
                                Of course, this temporary replacement BIOS does not contain any of the identity data from of the original and it also seems to take a while to boot, which makes me think that the ME data was not cleaned. It would be great if someone could take the identity data from the original BIOS (downloadable from the attached link) and put it into a clean Z50-70 BIOS for me. If you also need the serial number it is YB07250264
                                It would be even better if they could share how they did it so that next time I can be self-sufficient!
                                • Bonzas
                                  • 474
                                  • Indonesia
                                  #76
                                  You can learn from here
                                  https://www.badcaps.net/forum/showthread.php?t=103527
                                    VIP Moderator
                                    • Aug 2018
                                    • 4386
                                    • Bulgaria 🇧🇬
                                    #77
                                    Hi, I have a Lenovo Z50-70 (with Core i7-4510U and Nvidia GT820M) that wouldn't boot...
                                    • ianbak
                                      • Apr 2023
                                      • 59
                                      Perfect! Much reduced start-up times and Windows reactivated. Thank you so much!
                                        VIP Moderator
                                        • Aug 2018
                                        • 4386
                                        • Bulgaria 🇧🇬
                                        #79
                                        You're welcome.
                                        • dewodewo
                                          dewodewo
                                          • Feb 2022
                                          • 5
                                          • pendik
                                          #80
                                          Teşekkürler çalışıyor.
                                          Thanks working.
                                          [Mod. Edit-Vesko356] This is an english language forum, post in English please!
                                          • coasterghost
                                            Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                            by coasterghost
                                            For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                            Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                            Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                            System Hardware:
                                            Processor: AMD Ryzen 7 PRO 5850U
                                            Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                            09-08-2025, 10:46 PM
                                          • vpower
                                            Lenovo Z50-70 ACLUA/ACLUB NM-A273
                                            by vpower
                                            Hi, I have this laptop, it is completely dead, no charging light when connected to a working charger.
                                            Can anyone help me with some hints for troubleshooting this laptop?
                                            Thanks in advance...
                                            05-07-2024, 05:28 AM
                                          • atsio
                                            Boardview for lenovo z50-70 nm-a273 (aclua/aclub)
                                            by atsio
                                            In need for the above boardview.
                                            Thanks in advance
                                            06-23-2022, 04:51 AM
                                          • Disaxxx
                                            Lenovo Z50-70 ACLUA/ACLUB NM-A273 - Power circuit shorted
                                            by Disaxxx
                                            Hello
                                            Laptop - Lenovo Z50-70
                                            Motherboard: ACLUA/ACLUB NM-A273 Rev:1.0
                                            Vendor: HannStar
                                            I was doing some stuff on it utill I saw low battery notification. I have plugged AC adapter and immediately screen went blank. I thought that I was too late with plugging. However it stopped working after this. No LED.
                                            I have checked the board for short circuits.
                                            I noticed a malfunctioning mosfet - PQ302, so I have desoldered it. I checked its resistance, and it's really broken - R<1Ω
                                            However, pins 5, 6, 7 and 8 are still shorted...
                                            10-25-2020, 12:41 PM
                                            Lenovo 3000 Series Schematic
                                            Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                                            3000 C100 laptop with Braille keyboard
                                            Lenovo 3000 C
                                            C100, C200 - 15-inch XGA screen
                                            Lenovo 3000 N
                                            N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                                            N500 - 15.4 inch screen.
                                            Lenovo 3000 V
                                            V100, V200 - 12.1-inch WXGA models
                                            Lenovo 3000 G
                                            G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                                            10-04-2024, 06:05 AM
