Lenovo Yoga 15 locked bios
  • Scootie
    • Feb 2014
    • 133
    • Romania
    Hi there,
    My clients bios is locked. He bought it this was from a firm who were giving these away very cheap. The bios can be entered while pressing simply enter but nothing can be changed and all boot options are set to exclusive minus the lan card.
    The board is a ZIUS1 LA-B591P. Could really use a master password if there is one or some bios dump with schematic. Although I believe I located it but just to be sure.
    Thank you.
  • Scootie
    • Feb 2014
    • 133
    • Romania
    Re: Lenovo Yoga 15 locked bios
    Small bump for schematic. I managed to get a new bios but it still is locked and cant change anything within. I'm trying to locate where the SVP is on the board.
    • Life Goes On
      • May 2014
      • 264
      • Curacao
      The only way to do that is to replace the bios chip.
      The Night Drop Down, I Will Keep Try Until..., You Never know.
      Dushi Kòrsou, Nos Tei.
      • Scootie
        • Feb 2014
        • 133
        • Romania
        The bios chip doesnt contain the key, already tested that. The key is locked away somewhere else, hence the need for a schematic.
        • ridamouh159
          • Nov 2014
          • 365
          • maroc
          perhaps the password is in ene/ite/nuvoton
          you must to flash it or replace it
          • Scootie
            • Feb 2014
            • 133
            • Romania
            Maybe. Still, a schematic would be the best.
            • bilen
              • Aug 2014
              • 632
              • istanbul
              can you share files for this model
              • buglerbalint
                • Aug 2021
                • 13
                • Austria
                How can we remove the BIOS pwd?
                Here's the schematic, as an attachement.
                • Maxpower3
                  Bad Veteran
                  • Feb 2018
                  • 1224
                  • France
                  24s08
                  maybe same
                  https://www.badcaps.net/forum/showpo...13&postcount=8
                  • buglerbalint
                    • Aug 2021
                    • 13
                    • Austria
                    Originally posted by Maxpower3
                    24s08
                    Is this the PIN nr. 1?
                    • Maxpower3
                      Bad Veteran
                      • Feb 2018
                      • 1224
                      • France
                      if no chip, it's in the EC then
                      it depends on the version
                      rest only Kb9022 ??
                      look here for Kb9022
                      https://www.badcaps.net/forum/showpo...4&postcount=19
                      • buglerbalint
                        • Aug 2021
                        • 13
                        • Austria
                        rest only Kb9022 ??
                        That's bad news. I found it, it's an ENE KB9022Q chip with 124 pins.
                        Is it possible to read it with CH341? Maybe through the keyboard connector?
                        If I have the bin file could the lenovo tool remove the pwd or should I simply post here?
                        • Maxpower3
                          Bad Veteran
                          • Feb 2018
                          • 1224
                          • France
                          i use rt809f for that with adapter but it must be simpler, maybe with SVOD or others. unfortunately I don't know
                          auto patch not working!
                          just post your file here
                          or compare if implementation is same and change 0x200 to 022F (look at pics)
                          • buglerbalint
                            • Aug 2021
                            • 13
                            • Austria
                            Ok, thank you for your help!
                            I'll get back as soon as I have more time for it!
                            • opensourcefan
                              Lenovo X1 Yoga 1st Gen (model - 20FQ) with a locked BIOS
                              by opensourcefan
                              Hey all, I have a Lenovo X1 Yoga 1st Gen (model - 20FQ) with a locked BIOS. I would like to unlock it.
                              Currently I have it apart in all its glorious bits looking for the security eeprom that I can't find. Plan was to jump it. Next step I think is to pull the BIOS IC and flash a decryption file to it?? I'm a bit confused on that process.
                              1. Pull the BIOS IC,
                              2. Read and save the original locked file
                              3. Flash the decryption file
                              4. Install and boot up and remove password from BIOS
                              5. Remove BIOS IC again
                              6. Flash Original locked...
                              11-19-2022, 06:18 PM
                            • EleganceArog
                              Lenovo ThinkPad X13 Yoga Gen 3. BIOS LOCKED. Need Bios to be cleared.
                              by EleganceArog
                              I have a
                              S/N: [PW-042W7M]
                              Type Number: [21AXS1B200]
                              Motherboard: [LLX-2 MB 213016-SB]
                              Bios is locked with a Password. I'm looking for a cleared bios bin to flash the laptop.
                              I attached my backup bios.
                              Thanks in advance......
                              02-16-2024, 12:58 AM
                            • Wahaz
                              by Wahaz
                              10-30-2023, 08:42 PM
                            • HotSaladMan
                              Lenovo ThinkBook 14S Yoga ITL Bad Flash + Need Bios
                              by HotSaladMan
                              *##*#*#*#*#*#Cringe Warning Used Clips for Tl866ii Plus Backups#*#*#*#*#*#
                              Model : Lenovo ThinkBook 14S Yoga ITL
                              S/N : MP28JT19
                              MFG Date : 2022/02/09
                              Factory ID PRC4
                              MO : MPNXB26080FX
                              MTM : 20WE001US
                              MODULE FCC ID : PD9AX201NG
                              IC : 1000M-AX201NG
                              BOARD INFO
                              FLV34 LA-KO51P
                              REV : 1B 2020-08-24
                              Bit of Info
                              Using Tl866ii Plus, it would scan the chip but wouldn't not detect the
                              chip id, so i would always uncheck the id check, so it would bypass the error
                              i did in fact make...
                              11-07-2024, 07:46 AM
                            • beogeek
                              Lenovo Yoga Slim 7 14APU8 Bios Request
                              by beogeek
                              I've currently got a Lenovo Yoga Slim 7 14APU8 that is not posting. Its fan spins, the keyboard lights up, and the caps lock doesn't work. It was taken to some shop for cleaning, and then they updated or tried to update the bios. After that, there was no display and no post. I've removed the bios ic from the board and made a bios dump. I need some assistance going forward, as I suspect this is probably just a bad bios issue. I've tried searching for a dump, but no luck; if anyone can throw me a bone, it would be much appreciated!
                              Attached is the bios dump in the state I received it...
                              10-24-2024, 12:54 PM
