Dell vostro 1540 core i3
    I NEED THE TWO BIOS
    the board number is
    DV15 CP UMA MB
    10263-1
    48-4IP01-011
    thanks
    Re: Dell vostro 1540 core i3
    try this, bios and EC
      many thanks angel-boy
      i try and reaply
        and it works ?
          thank YOU
            Thank You Boss (angel-boy)
            mine work but keeps beeping 5 beeps
              5 bips mean problem cmos battery.change it.
                Thank You angel-boy
                  DELL VOSTRO 1540 -LAPTOP --- if 5 beep sound come ..can i use this bios update
                    5 beeps is not a bios issue. Check CMos battery voltage. If less then 3.0v then change it.
                      if 7 beep sound come . what is the problemme ?
                        7 beeps on dell indicates processor failure. The reason can be a corrupt bios, bad ram stick, Vcore circuit fault, Dramrst signal missing or even the cpu itself can be bad.There can be other possibilities.
