dell inspiron M531R-5535 bios dump needed
  • innocentforeign
    innocentforeign
    • Jun 2013
    • 172
    • KSA
    hi friends dell inspiron M531R-5535 Amd bios dump needed
    Mb code is : VAWO3 LA-9103P Rev:1.0
    thanks in advance
  • imranromi
    • Jan 2015
    • 1288
    • Pakistan
    Re: dell inspiron M531R-5535 bios dump needed
    Try this
    la-9103p bios i not sure this bios intel or amd check
    2 bios upload check if ok bios reply me.
    • innocentforeign
      innocentforeign
      • Jun 2013
      • 172
      • KSA
      thanks bro but i have already tried these files from same web but no luck
      • nimmay
        • Dec 2015
        • 82
        • Pakistan
        • imranromi
          • Jan 2015
          • 1288
          • Pakistan
          Try this.
          • nimmay
            • Dec 2015
            • 82
            • Pakistan
            thanks imran
            • Mazorca
              • Jan 2017
              • 463
              I have tried the above bin files, first two from imranomi did not work, one was too small, other correct size but programmer would not open. The third one opened and I was able to program it in, however, it still asks for the power-on password.
              Yes, I did try all the passwords possible from bios-pw.org and none worked.
              I reprogrammed the laptop to its original BIOS bin:
              Is the password elsewhere? The laptop shows an AMD BGA chip next to the bios chip.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Which kbc it uses?? If it is programmable kbc, then password may be stored there like kb9012 etc.
                • Mazorca
                  • Jan 2017
                  • 463
                  According to the schematics, it is indeed a KB9012QF-A3 LQPF128 14X14. How would I reprogram it? I have a TL866A.
                  I found this youtube video, and he says that I need an RT809F. Looks hard, but if things were easy, any fool would do them.
                  https://www.youtube.com/watch?v=SSeqlM3_LW8
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Its not that hard with Rt809F though svod is easier. You need to get any one of them or some similar programmer. Once you have the programmer in hand, members here will help you out. Dont worry about that part. Go ahead and buy one as this tool is a must for laptop repair these days as all new models have kbc programmed.
                    • Mazorca
                      • Jan 2017
                      • 463
                      The SVOD is a bit pricy for me:
                      https://www.ebay.com/itm/SVOD3-Progr...kAAOSw4aFanrAk
                      Right now, I only have one computer to fix, so the cost doesn't justify buying it.
                        • 21164
                        You can use a bus pirate, or a cheap ch341a programmer.
                        http://dangerousprototypes.com/docs/...ith_Bus_Pirate
                        • Mazorca
                          • Jan 2017
                          • 463
                          Thank your for the advice. I will order the ch341a programmer.
                            • 21164
                            If you prefer windows over linux you can use flashrom on windows.You`ll need the kb9012 patch as well, further down the page.
                            https://winraid.level1techs.com/t/gu...rammer/32948/3
                            • Mazorca
                              • Jan 2017
                              • 463
                              I had forgotten about this computer, customer never picked up and now I am finally trying to "fix" it. I have the ch341a programmer but I am not sure about the data input and output pins. According to the first website using a bus pirate, MISO = DO and
                              MOSI = DI. Problem is that my programmer has MOSI and MIOS. Just to make sure, is MOSI still DI and MIOS=DO?
                              I am using the windows program from the win-raid forum too.
                              • smali
                                • Sep 2014
                                • 287
                                • Pakistan
                                the password is stored kbc ....kb9012
                                • danbyers2
                                  • Jan 2025
                                  • 3
                                  • US
                                  Recently locked myself out so any help would be greatly appreciated. I've found lots of sites that help with the removal using the service tag but none that use the system disable code.
                                  Dell M531R-5535
                                  Tag: J6XPQY1
                                  System Disable Code: 6B9838CB75F9AB76
                                  Thank you very much for your time in advance because I realize you simply do not have to.
                                  • volinakis
                                    • Jan 2021
                                    • 2744
                                    • N/A
                                    Dell M531R-5535
                                    Tag: J6XPQY1
                                    try pass: 55200139 After type pass press and hold left Ctrl and hit Enter twice
                                    • danbyers2
                                      • Jan 2025
                                      • 3
                                      • US
                                      Thank you kindly!!
                                        SMDFlea commented
                                        Editing a comment
                                        Thread merged.
                                    • urad29
                                      Dell Inspiron 15 3511 Bios Needed
                                      by urad29
                                      I have a Dell Inspiron 15 3511 (Service tag: FY3C9T3) which is not booting past the Dell logo and I cannot enter the BIOS by pressing F2.
                                      I therefore believe that the BIOS is corrupted.
                                      I have spent some time trying to figure it all out as I have managed to reprogram BIOS's in the past.
                                      The motherboard has two chips, one is a 25Q64JVSIQ and the other is a 25Q128JVSQ.
                                      Firstly, how do I know which one is the BIOS, or are they both BIOS (have only worked on single BIOS boards).
                                      Secondly, I cannot seem to get a bin file or the like from the BIOS exe...
                                      03-21-2023, 03:46 PM
                                    • jacospama
                                      Dell inspiron 15 3520 Bios needed
                                      by jacospama
                                      Reg Model- p112f
                                      REg type- p112f00f
                                      Services tag- BLW01Z3...
                                      03-25-2025, 09:30 AM
                                    • zlr8r
                                      looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
                                      by zlr8r
                                      looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
                                      cheers
                                      Dell Inspiron 17 (7786) Laptop
                                      Service Tag: 5J0NHT2
                                      Bios: 1.9.0
                                      MOBO: RO 15 17 WHL 2GB MB / 18706-2
                                      Attached;
                                      1. My saved bios using a programmer
                                      2. Dells Bios updater .exe (v1.16)
                                      3. Dells Bios recovery file
                                      4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
                                      5. Image of ME...
                                      12-18-2023, 03:08 PM
                                    • DynaxSC
                                      by DynaxSC
                                      11-17-2023, 10:56 AM
                                    • mikeybass
                                      by mikeybass
                                      04-23-2025, 04:30 PM
