Bios asus x45u dump please
  • kubsky
    kubsky
    • May 2014
    • 7
    • Indonesia
    Mainboard: asus x45U rev: 2.1
    thank you so much
  • meritosari
    • Oct 2010
    • 774
    • Indonesia
    Re: Bios asus x45u dump please
    thank you so much
    backup the old one, and try this bro:
    • cyberant
      • Mar 2015
      • indonesia
      my mobo can't initialize hardisk i hope this work for me.. thanks
      • ariful18
        • Aug 2016
        • 20
        • Bangladesh
        Asus X45u Rev-2.1 AMD With AMD Graphics
        • Andyservo
          • Jun 2013
          • 152
          • Indonesia
          thank you all..
          • razor_amd
            by razor_amd
            12-15-2020, 07:07 PM
          • DynaxSC
            by DynaxSC
            06-14-2024, 03:49 PM
          • Ahari
            by Ahari
            I...
            08-13-2025, 06:12 AM
          • jbonavita
            by jbonavita
            Some issues
            Things I tried
            04-29-2025, 09:38 PM
          • kodox
            Asus ExpertBook B1400CB Bios Dump Needed
            by kodox
            need original bios dump, original bios has flashed by other technician before me.
            attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
            unit info:
            Model: Asus ExpertBook B1400CBA-0711A1235U
            S/N: R6NXNZ006657238
            CN: 7F6F
            Mainboard Code: B1500CBA R2.1...
            08-16-2025, 12:20 PM
