need key combination to enter bios update on asus x551mav
  • barby16_06
    • Jul 2014
    • 24
    • romania
    hi all. i have an asus x551mav with bios failure. it's power on when i push power button but no image, no post, no sound, nothing.
    bios chip is w25q64fw - with 1.8v power and my ch341a have 3.3 power
    the only way to flash bios is to enter in bios update from keyboard but i don't know key combination. i know that on acer it was fn+ esc, and on some asus is whas ctrl+home and power buton, but at this model of asus i didn't get in update mode.
    if anybody know how to enter in update menu please help me.
    thanks.
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3577
    • slovakia
    Re: need key combination to enter bios update on asus x551mav
    this bios ic is in supported ic for ch341 so i dont thik u have problem with flashin
    • razor_amd
      by razor_amd
      12-15-2020, 07:07 PM
    • throwaway327
      by throwaway327
      Model No: RC72LA
      Serial No: SBNVKD001014459
      06-18-2025, 05:52 PM
    • davidebeatrici
      Asus X541UV Windows update KB5063060 deleting BootOrder EFI environment variable? bios fix
      by davidebeatrici
      I had 3 people contact me in a week because Windows suddenly didn't boot:
      As you can see, all 3 are ASUS computers, but I believe the common factor is the BIOS being American Megatrends (AMIBIOS/APTIO).
      The first two recovered just fine after a restart, but the third one didn't and was brought to me. The model is F541UV (X541UV).
      Setup allows to add a boot option manually and the operating system boots just fine from both bootx64.efi and bootmgr.efi. However, there is no way whatsoever to save the option(s): upon a reboot the machine goes straight...
      06-17-2025, 12:59 PM
    • jinki_dadou
      ASUS ExpertCenter D700MD need update bios
      by jinki_dadou
      helle
      in have asus desktop
      model : D700MD-5124000950
      CPU i5 12400
      I wanted to upgrade the processor i7 13700
      when I change the processor show black screen and fan spinning fast
      i ask asus technical support
      the answer : include microcode in the latest update bios
      he give me file 1 update bios
      2 microcode
      2 fils in tha attachments please help me
      ( sorry for my dab english )...
      05-18-2025, 02:20 AM
    • mikeybass
      by mikeybass
      04-23-2025, 04:30 PM
