Asus X102ba bios dump.. need..
  • ry x hunter
    • Jun 2013
    • 184
    • philippines
    hello guys i need help to find bios dump for my asus x102ba netbook..
    thanks..
  • dycc
    Vision
    • Nov 2011
    • 625
    • Côte d'Ivoire
    Re: Asus X102ba bios dump.. need..
    try
    • dj_ricoh
      • 2073
      • uk
      whats wrong with it mate?
      • ry x hunter
        • Jun 2013
        • 184
        • philippines
        the monitor goes blank
        • josuemcp
          • Feb 2012
          Show...
          Thanks.....
          • youssef_57
            • Apr 2017
            • 13
            • egypt
            thank you
            • alas3376
              • Nov 2011
              • 382
              • BENIN
              hi
              need ec dump for this
              thank you
              • peste
                • 13200
                • ROMANIA
                Originally posted by alas3376
                hi
                thank you
                try..
                • alas3376
                  • Nov 2011
                  • 382
                  • BENIN
                  Originally posted by peste
                  try..
                  thant you
                  • chemseddine
                    • Jul 2017
                    • 32
                    • algeria
                    thankssssssssss
                    • MasterEd
                      • Oct 2020
                      • Philippines
                      X102ba rev 2.0 need bios dunp working thankyou
                      • peste
                        • 13200
                        • ROMANIA
                        try post#2
                        • razor_amd
                          by razor_amd
                          12-15-2020, 07:07 PM
                        • DynaxSC
                          by DynaxSC
                          06-14-2024, 03:49 PM
                        • Ahari
                          by Ahari
                          I...
                          08-13-2025, 06:12 AM
                        • jbonavita
                          by jbonavita
                          Some issues
                          Things I tried
                          04-29-2025, 09:38 PM
                        • kodox
                          Asus ExpertBook B1400CB Bios Dump Needed
                          by kodox
                          need original bios dump, original bios has flashed by other technician before me.
                          attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
                          unit info:
                          Model: Asus ExpertBook B1400CBA-0711A1235U
                          S/N: R6NXNZ006657238
                          CN: 7F6F
                          Mainboard Code: B1500CBA R2.1...
                          08-16-2025, 12:20 PM
