lenovo g505
  • alihomee
    • Dec 2012
    • 1575
    • malaysia
    lenovo g505
    need bios file for this model having no display issue
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: lenovo g505
    backup old bios and try this
    not my work, found on net
    Im Back... sort of...
    • meritosari
      • Oct 2010
      • 774
      • Indonesia
      Re: lenovo g505
      board code?
      LA-9912p?
      • WGenius
        • Apr 2015
        • 31
        • Algeria
        Re: lenovo g505
        well, board code doesn't really matter in this case, unless you do bios mods, what matters is the product name (lenovo G505) and model name (e.g. 1066).
        Anyway, here it is (if ala_borbe and meritosari BIOS doesn't work for you).
        sigpic
        • minhaj
          • Jul 2015
          • 13
          • india
          Re: lenovo g505
          thank u soooo much
          frnds
          • onzey
            • Oct 2016
            Re: lenovo g505
            Hi
            I realise this thread is a little old, but I've recently been helping someone with a Lenovo G505 which had a 'no display issue' on the laptop screen but was fine on an external monitor.
            However I discovered a way to get correct boot so that laptop screen display is visible (including Lenovo splash screen, and incidentally, the webcam to be recognised correctly in device manager) was to press power on button and immediately close the laptop lid and reopen it, i.e. open the laptop screen just enough to press the power button, then close and open virtually straightaway.
            Does anyone know if any of the bios files available from this thread fix this problem or are they for some other 'no display issue'?
            • fraig
              • Nov 2014
              • 36
              • cairo
              Re: lenovo g505
              Originally posted by onzey
              Hi
              didn't successful
              • String2016
                • Nov 2015
                • 2236
                • philippines
                Re: lenovo g505
                Thank you so mch bios of meritosari works for LA-9112P
                • bayoumcs
                  • Aug 2015
                  • indonesia
                  Re: lenovo g505
                  thanks my bro. its work. la-9912p
                  • shyammax
                    • Jun 2017
                    • india
                    Re: lenovo g505
                    all voltage are ok and also flash bios with file which is downloaded from here but no display what is the matter
                    • ariffujjaman
                      • Oct 2016
                      • 8
                      • bangladesh
                      Re: lenovo g505
                      Thank you somch WGenius
                      • tano2060
                        • May 2018
                        • 27
                        • Macedonia
                        Re: lenovo g505
                        Nice.
                        Thanks.
                        • Forest79
                          by Forest79
                          07-23-2023, 07:39 AM
                        • survivalbloke
                          Unable to extract bios file from Lenovo bios exectuable
                          by survivalbloke
                          I'm trying to extract a flashable bios file(ch341a) from the lenovo bios executable download. I have tried the instructions from this site https://starkeblog.com/lenovo/uefi/2...pdate-exe.html, which are not working. According to those instructions, after issuing the command
                          Code:
                          "innoextract 7wcn38ww.exe"
                          it should create an \app folder, inside which, I should find a newly created "7wcn38ww.exe" file. I should then be able to extract that using 7zip and find my .FD file.
                          The trouble I'm having is that I'm not getting the newly...
                          06-12-2024, 07:55 AM
                        • survivalbloke
                          Unable to extract Lenovo BIOS file from installer
                          by survivalbloke
                          I'm working on a Lenovo LOQ 15APH8, Serial# MP2L9MAV. I want to flash a new BIOS onto it, but I'm also trying to learn this process for my own enrichment and professional development.
                          I was watching some tutorials, copying the serial info blocks from the old bios to a new bios. Before that though, they use innoextract on the Lenovo .exe. I downloaded Innoextract v1.9 but it tells me my .exe is not a supported inno setup installer(see screenshot). So if I unpack this using 7zip, I do get a .ROM file, but according to my tutorials, I'm looking for a .FD file.
                          How can...
                          07-16-2025, 03:21 PM
                        • maanee11
                          Help to get Lenovo BIOS bin file for Thinkpad T560
                          by maanee11
                          Hello Everyone,
                          I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                          https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                          In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                          05-15-2022, 11:59 AM
                        • mafioso3
                          lenovo x13 yoga gen1 EC bios file from (npce388)
                          by mafioso3
                          hello
                          i'm looking for lenovo x13 yoga gen1 EC bios file from (npce388)
                          i have already downloaded the bios file from lenovo website ,but after decompressing the EXE file,i only got FL1,no way to extract EC from it.
                          could someone please upload a unlocked npce388 EC file?
                          thanks in advance
                          SOLVED
                          03-13-2023, 02:20 AM
