Lenovo G460 slow even in bios
  • lezsimply
    The Wanderer
    • 646
    • Philippines
    Good day. I don't know where to start from but this laptop shows sluggish performance even in bios. Its like in slow motion. Hard drive is not the culprit because I have used good working ones. I also tried to boot off hiren's bcd without hard drive installed same situation.
    It does not freeze or shutdown just in plain slow motion. Checked core voltage measures 1.2v stable. It has an i3-330m processor. I tried to use i3-350m but does not show display although its working on other board. What do you think guys? Thanks
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3608
    • slovakia
    Re: Lenovo G460 slow even in bios
    i have this problem but with old processor. when its overheated something in it burn/l2,l3 cache/ and processor slows down.
    • lezsimply
      The Wanderer
      • 646
      • Philippines
      I'll try to replace tantalum caps found underneath socket. I also observed that heatsink is very clogged. Haven't removed the board from case but tomorrow I'll try. Thanks ktm
      • highpulse
        i hate HP
        • May 2013
        • 1488
        • portugal
        you should first chek wich temp you achieve on the cpu area , use a good OMEGA temp reader, the most tin one is the more accurate put it right on the die , and use a termal pad , to avoid making to much pressue on the die , just make sure you dont force to much when screwing dont forget with a pad it will make more pressure , so screw like 2/3 . and chek temp you're getting .
        • lezsimply
          The Wanderer
          • 646
          • Philippines
          Dont have that kind of device as of now. But I managed to get few readings from software which indicates 52c upon startup. These are based on hwinfo, hardwaremonitor and siw. Some say it maybe from damaged sensors. Better test with a known good processor to eliminate it as the problem. thanks high
          • tomodachi
            • Apr 2012
            • 603
            • Turkey
            Sounds like corrupted BIOS .
            I suggest you to flash the BIOS with original one, happened me at a Lenovo netbook and I fixed it with reflashing.
            • lezsimply
              The Wanderer
              • 646
              • Philippines
              Ok I will try that. Thanks tomo.
              • highpulse
                i hate HP
                • May 2013
                • 1488
                • portugal
                yes as tomodachi alto stated , if a flash with incorrect ME region will make this things to happen .
                • smali
                  • Sep 2014
                  • 287
                  • Pakistan
                  @Lezsimply what are the updates of your fault.
                  is it tace out? have you tried another processor.
                  • claudyu07
                    Claudyu07
                    • May 2014
                    • 125
                    • Ireland
                    As other guys recommended check for CPU temp.
                    Faulty ram module can give same simptoms.
                    You can use memtest from bootable CD/USB and see
                    • lezsimply
                      The Wanderer
                      • 646
                      • Philippines
                      I have done all basic to advance test before posting here. I still can't test other processor as it seems to not boot when using other processor. I haven't found a good working bios as of now. will soon update you guys. Thanks very much.
                      • tushiwarashi
                        • Jun 2015
                        • philippines
                        heyy guysss whats the update on this thread? i also have the same problem sir lez... lenovo g460 with i3 m370... also lagging on bios... tried upating the bios still the same... tried cleaning and applying thermals paste and cleaning the fans etc... i notice it starts to slow down when i play videos... tried tinkering this laptop like 5x now still the same... its working fine on browsing but when i play games and videos is slowing down... i tried alot like replacing rams... reinstalling a windows xp windows7 both 32 and 64 still friggin the same... and asides... the wifi and the lan devices cannot be detected so im using a wifi usb stick for it to work...
                        sir lez can you add me on fb? ur from bulacan and just from nueva ecija...
                        • HarryPK
                          • Mar 2014
                          • 210
                          • barabai
                          Is the prob fixed? Please share
                          • RJARRRPCGP
                            • Jul 2004
                            • 6304
                            The slowness sounds just like a disabled L1 cache on old school processors.
                            ASRock B550 PG Velocita
                            Ryzen 9 "Vermeer" 5900X
                            Arc A770 16 GB
                            eVGA Supernova G3 750W
                            Alienware AW3423DWF OLED
                            • Neil_from_wales
                              • Jun 2015
                              • Wales
                              Have you done the obvious things - (clean out fan & heatsink, apply fresh thermal paste/pads to cpu & gpu, set bios to "setup defaults" or "fail safe")?
                              Also, if you disconnect everything (battery, hard drive, USB board, keyboard, wifi, bluetooth, DVD etc etc & all ram except one stick) - does it still run slow in bios? Check it with each individual ram stick.
                              My bet is the gpu is at fault. What temps does HWINFO give for gpu at startup?
                              • lezsimply
                                The Wanderer
                                • 646
                                • Philippines
                                I haven't fix the issue on this laptop. Got a lot of other boards to fix. I still got no go on bios file. If bios flash fail might as well be a gpu or sb, dont you think so?
                                • looofy
                                  • Jul 2015
                                  • 34
                                  • sudan
                                  its a processor issue
                                  did you test its processor in other main board ?
                                  did you make sure the processor socket is clean ?
                                  dose the main board work with any ram slot (single ram) ?
                                  • manu de hanoi
                                    • Jul 2018
                                    • vietnam
                                    I found out the issues:
                                    1)CPU overheat: the fan finns clog very easily, remove the whole heat pipe assembly (by unscrewin around CPU & GPU), and thoroughly clean between the fins
                                    2) GPU overheat (causing CPU to run at half speed when GPU over 80C and killing the system above 100 or so): There was a f*@#$ silicon pad between GPU and heat pipe (grey soft thing),I believe it was there to adjust the height because GPU was too far for copper heatsink. THE FIX: carefully bend down the wings (while keeping pressure on the copper rivets so that the wings dont detach) that connect the GPU heatink to the screw hole so that when screwed the heatsink presses downward one milimeter further
                                    • manu de hanoi
                                      • Jul 2018
                                      • vietnam
                                      I meant the heat pipe fins near the fan
                                      • lucaszmn
                                        by lucaszmn
                                        Problem:
                                        Initial Findings:
                                        • I concluded that the
                                        08-12-2025, 03:01 PM
                                      • Wahaz
                                        by Wahaz
                                        10-30-2023, 08:42 PM
                                      • grimacelord
                                        by grimacelord
                                        Hello there.
                                        History:
                                        03-15-2023, 03:29 PM
                                      • jendkkd jeje
                                        Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                        by jendkkd jeje
                                        So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                        I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                        10-11-2024, 03:12 PM
                                      • 1g0r
                                        Lenovo ThinkPad L15 G3 Bios 1 IC conductor track
                                        by 1g0r
                                        First, the data in brief:
                                        Manufacturer: Lenovo
                                        Model: ThinkPad L15 G3 21C3-0016GE
                                        motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
                                        IC Bios 1: MX77L25650F
                                        IC Bios 2​: MX25L25673G
                                        EC Chip: NPCX997KAABX
                                        So far I've been a silent reader, but now I need your help
                                        I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
                                        I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...
                                        The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge
                                        01-18-2025, 02:39 AM
