Dump bios file for toshiba L350-156
  • kamel
    • May 2011
    • 129
    • TUNISIA
    Hi !
    Need urgently a dump bios bin file for toshiba L350-156
    Platform : 6050A2170201-mb-A03
    Thank you
  • polytek
    • Dec 2013
    • 496
    • TUNISIA
    Re: Dump bios file for toshiba L350-156
    try this:
    • kamel
      • May 2011
      • 129
      • TUNISIA
      Originally posted by mabroukmedal
      try this:
      Thanks for the dump file.
      It works but didn't help the lap shutting off after a display of 1 to 2 seconds.
      • laptech2
        • Nov 2015
        • Ghana
        Working
        • toufik sat
          • Feb 2016
          • 136
          • los angles
          Thank you
          • ricaik2005
            • Feb 2017
            • 22
            • Ghana
            grateful laptech2 works perfectly
            • lrservicios
              • May 2016
              • 135
              • españa
              Here i attach Working Bios for
              6050A2170401-MB-A03
              toshiba Satellite L300 / L350 Intel Board
              V000138330
              • tano2060
                • May 2018
                • 28
                • Macedonia
                Working
                • Nwokem ugochukwu
                  • Jan 2021
                  • 9
                  • Nigeria
                  I need dump bios file for TOSHIBA FSEPSY2 A4144A
                    • 21641
                    This is the 3rd time you`ve hijacked this thread,plus ive sent you 2 private messages.................
                    Look here: https://www.badcaps.net/forum/showthread.php?t=91301
                    • JdogTheGreatOne
                      Big Nerd
                      • Mar 2023
                      Apparently this may be because of a bad NEC tokin chip that should be replaced with 4 capacitors. If you're interested in that repair I'm considering taking a stab into component level repair. I believe the link I'll post will have the correct capacitors but I could be wrong.
                      https://www.badcaps.net/forum/showthread.php?t=46821
                      https://www.digikey.ca/en/products/d...hoCjP8QAvD_BwE
                      • HerrAbisZ
                        • Jun 2024
                        • Austria
                        Hi, I have a Toshiba Satellite L350 - 23L PSLDCE - 00N00DGR
                        Which BIOS works here please?
                        And how do you handle these files, because normally I know them as .exe files
                        Thanks for your help​
                        Klicke auf die Grafik f?r eine vergr??erte Ansicht  Name: jpg Ansichten: 0 Gr??e: 528,6 KB ID: 3293750
                        • Citymin
                          by Citymin
                          S/N : 5RNK9FFT70...
                          08-05-2025, 05:12 AM
                        • bondminer009
                          Need Bios for Latitude 7650 (No Original / dump bios file)
                          by bondminer009
                          Good Evening,
                          Need help, is there any possible to get the bios file? Because received from my team without any dump file / original bios file
                          Thank You
                          Salam,
                          Three
                          11-12-2024, 07:48 AM
                        • DProf.
                          TOSHIBA DYNABOOK T55/AB, PT55ABP-BJA2 BIOS DUMP
                          by DProf.
                          High great minds, please i need bios dump for this system .or help to REMOVE the PASSWORD in my original dump
                          Toshiba Dynabook T55/AB, PT55ABP-BJA2
                          MODEL NAME. Satellite L50-D series
                          P[ART NO PS57MN-00600R
                          Attached is my original bios dump ADMIN. PASSWORD LOCKED. Thank you in advance....
                          09-26-2024, 04:30 AM
                        • joshAU
                          BIOS file for N550JK (original dump attached)
                          by joshAU
                          Hi all.
                          I'm looking for a BIOS file for an Asus N550JK.
                          I have a Asus R552J, which I believe is identical to the Asus N550JK.
                          I downloaded the latest BIOS (210) for the R552.
                          It is named N550JKAS.210.
                          The BIOS file is however only 6mb in size.
                          I've read the chip with a CH341A programmer and verified the file.
                          That file is actually 8mb in size.
                          I'm wanting to remove the BIOS password from this unit.
                          It prompts you to input the password when turned on, so its sort of behaving like a power on password rather than...
                          08-09-2022, 08:06 PM
                        • adelage
                          Merge ECS Z77-H2 bios cap file with original dump
                          by adelage
                          I am trying to recover an ECS Z77-H2 motherboard, I dumped the original bios with a ch341a programmer, the bios from the manufacturer is a .cap file of smaller size, and it seems that I need to merge this file with other information from the dump, anyone can explain how to do that?
                          03-11-2025, 03:07 AM
