Support for Asus ROG G73 rev2 Bios/Schematic?
  • magneh
    • Apr 2014
    • 588
    • Portugal
    Hello!
    Got this beast in a quite bad shape ... touchpad ribbon cable with a burned track ... whatever.
    The owner said he bought it like this ... he said also that sometimes the laptop would POST and he entered the bios one or two times, but most of the time there's no VIDEO.
    Well I tried a reflow on the GPU, and it when shorted after. Reballed it and short was gone.
    Assembled it and it turned on, fans spin, and no video.
    2nd time the same. A few hours I turned it on and I got image with ASUS first image, but with blue tonality.
    I could get into BIOS and selected Default setting and saved.
    Never got image again the few times I tried to turn it on.
    This is a garantee that's not BIOS issue neither GPU?
    This said, and I've tried hard to find BIOS os schematic, but no luck.
    Could some one help me with this?
    Some photos attached.
    Thanks!
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: Support for Asus ROG G73 rev2 Bios/Schematic?
    i bet on gpu! relowed 3-4 of them... never had any other issues, only vga... and always use asus vga driver its different from ati vga driver, you will have freeze/bsod issues.. on some versions of bios lan disappear from device manager, but clear cmos fix this
    if you get it working flash modded bios, you will get voltage settings and fan speed settings in bios
    http://forum.notebookreview.com/thre...os-mod.670921/
    Im Back... sort of...
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3597
      • slovakia
      if u reball it, try to reflow or reball again.
      • magneh
        • Apr 2014
        • 588
        • Portugal
        Hello!
        Well I've tried to make some more test to this MB and here what I've found.
        First, I could never get the board to POST and show video again.
        Second, when I plug charger board powers up all by herself. If I press PW some seconds she shuts down. And if I press again, she turns on.
        This behavior is not 100% garantee. sometimes I plug the charger and the board DOESNT power up by herself.
        Mesured coild on GPU (see photo) . arent some too low?
        Well, removed GPU and black pastic protection that was underneath her , and I saw a burned component.
        The question is that it isnt labeled, and It's impossible to read PN.
        I bet it's similar to the one next to it... I had to leave office and I'll check it better tomorrow.
        Here are some pics.
        How do you guys proceed in this case to know what PN is it?
        Thanks!
        • magneh
          • Apr 2014
          • 588
          • Portugal
          Hello!
          Any one with more experience on these GPUs could tell me if those values on coils arent too low ?
          How to correct identify tht burned IC without schematic?
          Thanks for any inputs!
          Cheers.
          • razor_amd
            by razor_amd
            12-15-2020, 07:07 PM
          • grimacelord
            by grimacelord
            07-10-2025, 02:52 PM
          • lrouw84
            by lrouw84
            Hi there,
            01-28-2023, 01:31 PM
          • nd03
            Asus Q326FA Rev2.0 (UX362F/FA) BIOS
            by nd03
            Please I would need the Q326FA REV2.0 Bios cleared. Somehow my laptop I fixed got corrupted and it will not power on display (including backlight).
            This is my current BIOS. It was ok display was coming up while I was debugging something and suddenly it stopped. If it helps the battery indicator blink 4 whites. CPU fan spins. I have VCC Core rails. VCC GT (graphics) not coming up but no short I think Bios is not requesting graphics.
            Laptop Model: UX362F
            Motherboard Q326FA Rev2.0
            There was an issue with intermittent display flicker so I was working on...
            02-13-2024, 01:58 PM
          • macabook
            by macabook
            🧩 Initial Issue
            07-24-2025, 02:17 PM
