Need K55A Bios Dump
  • SirangKap
    • Feb 2020
    • 29
    • Philippines
    #41
    Re: Need K55A Bios Dump Repair
    Originally posted by peste
    the posted bios is longer..be careful when writing and reading..try..if it doesn't work, post pictures with the stickers on the motherboard (white or green) ..
    Thank you sir. I will try this again and let you know if it fix the problem. If not then i will post here the photo of my motherboard. Thanks again for the help,much appreciated.
    • SirangKap
      • Feb 2020
      • 29
      • Philippines
      #42
      Hello sir, have a nice day. Update the board that i'm working on. I tried your uploaded bios sir but unfortunately the problem didn't solve. At first it powers on with the fan not spinning,but the display comes on. After a few seconds the fan spins slowly then it spins like crazy(very fast) then the laptop restarts again doing the same thing. i did check the processor heatsink if it is overheating and no,i even put a fresh thermal compound on the processor.
      I've attached here the original photo of my motherboard sir if you can help me fix the bios or something in the board. thanks so much in advanced for your time helping other people.
      PS: Additional information sir. I did notice this chip(encircled with red) getting hot during booting and rebooting of the board. I don't know if it's normal.
      • peste
        • Dec 2016
        • 13209
        • ROMANIA
        #43
        try..
        • SirangKap
          • Feb 2020
          • 29
          • Philippines
          #44
          try..
          thank you sir for the help. i will try again this one and let you know if it will fix the problem.
          • SirangKap
            • Feb 2020
            • 29
            • Philippines
            #45
            try..
            this didn't solve the problem sir. still the same status as i mentioned above.
            • SirangKap
              • Feb 2020
              • 29
              • Philippines
              #46
              Hello.. Have a good day to everyone.
              Please help,can anybody here help me clear the ME region of this bios,so that i can test it to my asus motherboard? i tried it today and it powers on,the fan spins the same as before but now it is not restarting. maybe this will work if the me region will be cleared.
              • peste
                • Dec 2016
                • 13209
                • ROMANIA
                #47
                try..
                • SirangKap
                  • Feb 2020
                  • 29
                  • Philippines
                  #48
                  try..
                  Update;
                  I tried this bios you have uploaded sir,but it seems that there is no solution to my laptop. i tried many bios version but the status is still the same. some are worse and some are better than other. but just the same,the problem didn't solve. i will attached here a video of my laptop showing your bios and notice how the fan spins.
                  • atbykls
                    • Feb 2021
                    • 26
                    • turkey
                    #49
                    Thank you for your effort.
                    • RotVik
                      Learning...
                      • Feb 2016
                      • 56
                      • Mexico
                      #50
                      Originally posted by qayyum786
                      try
                      You saved my ass kind sir, thanks!
                      • Ahari
                        by Ahari
                        I...
                        08-13-2025, 06:12 AM
                      • Habble7
                        by Habble7
                        Suspected Cause:
                        Troubleshooting Attempts:
                        05-22-2025, 07:28 AM
                      • haitham sharabati
                        [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                        by haitham sharabati
                        Hello engineers 😀,
                        I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                        🔧 Device Info:
                        - Model: HP 15-da2007ne
                        - Product Number: 8XF55EA#ABV
                        - Serial Number: CND0338P0D
                        - CPU: Intel Celeron N4000
                        - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                        💀 Problem:😅
                        - Device shows “Administrator Password”...
                        08-07-2025, 04:54 AM
                      • Citymin
                        by Citymin
                        S/N : 5RNK9FFT70...
                        08-05-2025, 05:12 AM
                      • DynaxSC
                        by DynaxSC
                        11-17-2023, 10:56 AM
