HP OMEN MAX Gaming Laptop 16-ah0005nl, please remove password
  • inspirim
    • May 2013
    • 298
    • Italy
    Please remove the administrator password and power password.
    Model: OMEN MAX Gaming Laptop 16-ah0005nl (BE7D1EA)
    ProdID: BE7D1EA#ABZ
    Serial: 5CG5321C3L
    I'm attaching the BIOS.
    Thanks everyone.
  • peste
    • 15856
    • ROMANIA
    ProdID: BE7D1EA#ABZ
    Serial: 5CG5321C3L
    Thanks everyone.
    bios extracted from the HP website update for OMEN MAX Gaming Laptop 16-ah0005nl (BE7D1EA), the laptop has two bios variants, the one is 08D41....
    DMI 1100000 - 110103F
    If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our boardview / schematic archive.
    It only takes 1 minute:
    https://www.badcaps.net/settings/subscriptions
    • inspirim
      • May 2013
      • 298
      • Italy
      ProdID: BE7D1EA#ABZ
      Serial: 5CG5321C3L
      Thanks everyone.
      Thanks, it works, but I have a problem. When I turn on the notebook, it gives me the following message: manufacture programming mode is in unlock mode
      and it can't be disabled from the BIOS.
      The serial number and product ID aren't yet in the BIOS. Is it possible to remove the password from the original BIOS to have the entire original configuration?
      Can you help me?
      Thanks everyone!
      • peste
        peste commented
        Editing a comment
        the bios from post #2 is virgin, use the HxD program (it's free on the internet), enter both bios into the program (your laptop and the virgin one),
        select that interval mentioned (DMI) in both bios, copy the interval in your bios and pass it to the virgin bios (copy - paste)....and that's it...
    • Sparo
      Quicksilver
      • Jan 2022
      • 4831
      • M\A
      • Anime, Edge Computing, Football, Snooker
      Can you help me?
      Thanks everyone!
      Hi, here is what you requested. Try this file
      Enjoying our forum? Subscribe to unlock extra perks!
      >> Upgrade here <<
      • inspirim
        • May 2013
        • 298
        • Italy
        Thanks, I tried, but what about the password? It says: Enter Administrator Password or Power-On Password
        • Sparo
          Quicksilver
          • Jan 2022
          • 4831
          • M\A
          Really? That didn't remove the password. Anyway. Just follow what peste said and copy the DMI data using HxD from the original BIOS backup to the new 08D41.bin file
          That should fix the "manufacture programming mode is in unlock mode" issue. If you somehow can't do it yourself, just let us know and we'll do it for you
          >> Upgrade here <<
            • 24907
            Bios + DMI.
            • inspirim
              • May 2013
              • 298
              • Italy
              If you could do it for me, I'd be very happy. I'm not very good at programming. Thank you for your time, removing passwords.
              Thank you all.
              • m1ch43lzm
                • Mar 2019
                • 2962
                • Peru
                Thank you all.
                Use the BIOS from post 7 by SMDFlea, it will show "Manufacture Programming Mode is in Unlock mode" but should have the correct DMI (S/N etc.)
                To fix that, download HP BCU
                https://ftp.ext.hp.com/pub/caps-soft...it/HP_BCU.html
                Usage
                Originally posted by m1ch43lzm
                BCU should be run from Command Prompt as Administrator
                Usage:
                C:\SWSetup\SP143621>BiosConfigUtility.exe /get:config.txt
                Edit config.txt, check if S/N etc. is correct, then change this:
                Code:
                Manufacturing Programming Mode
                *Lock
                Unlock
                Remove the * from *Unlock and change to *Lock
                Save, and run BiosConfigUtility.exe /set:config.txt
                • Sparo
                  Quicksilver
                  • Jan 2022
                  • 4831
                  • M\A
                  Thank you all.
                  SMDFlea was already kind enough to do it for you. See the post #'7 above
                  > https://www.badcaps.net/forum/troubl...01#post3904201
                  EDIT: m1ch43lzm was also kind enough to show you how to fix the "manufacture programming mode is in unlock mode" issue if it persists
                  >> Upgrade here <<
                  • inspirim
                    • May 2013
                    • 298
                    • Italy
                    I understand, thanks to everyone for their cooperation
