Hp 650 bios
  • Luís Amaral
    • Nov 2013
    • 78
    • Portugal
    Hp 650 bios
    Hi, need bios dump for HP 650
    Motherboard:
    PALWONN M3
    Anyone could help i will be appreciated
  • dj_ricoh
    • 2073
    • uk
    Re: Hp 650
    did you try HP website?
    do you know how to look for the BIOS?
    Ok i tell you!
    under the battery there is a sticker.
    find the model nr there and go to HP and write down the full model and bam bam VOILA drivers and a bios EXE file.
    after that you install 7zip and right click the exe file and select open in archive; 2nd time the same and you will find there files like 1mb 2mb 4mb and you write the one you need
    How to BIOS !
    we can`t help you if we don`t know the full model of the notebook
    • Luís Amaral
      • Nov 2013
      • 78
      • Portugal
      Re: Hp 650
      The bios is bigger then 4mb I need the dumps ec and main !
      • loser18
        • Nov 2013
        • 274
        Re: Hp 650
        What's the mobo part no., CPU architecture & SIO/EC/KBC number?
        • Luís Amaral
          • Nov 2013
          • 78
          • Portugal
          Re: Hp 650
          Hp 650
          newton_cr&hr_hpc
          mv_mb_v1
          cpu: Intel
          kb: It8518e
          • loser18
            • Nov 2013
            • 274
            Re: Hp 650
            Discrete or UMA?
            • loser18
              • Nov 2013
              • 274
              Re: Hp 650
              Try this one...
              • Luís Amaral
                • Nov 2013
                • 78
                • Portugal
                Re: Hp 650
                Uma
                • Luís Amaral
                  • Nov 2013
                  • 78
                  • Portugal
                  Re: Hp 650
                  Same symptom turn on and no image, when i flashed the main my programer give me this warning:
                  Some data out of memory.
                  Could be problem ?
                  I'm going to check the voltages around KB
                  • loser18
                    • Nov 2013
                    • 274
                    Re: Hp 650
                    Replace the SPI...must be faulty...Probably damaged blocks...
                    • Luís Amaral
                      • Nov 2013
                      • 78
                      • Portugal
                      Re: Hp 650
                      The size of the main that you give me is (4.198.400 bytes) is it bigger then 4MB of the BIOS ?
                      • loser18
                        • Nov 2013
                        • 274
                        Re: Hp 650
                        I haven't tested this myself...
                        It's 4098KB & it suppose to be 4096KB...
                        DON'T USE IT...DON'T USE IT...DON'T USE IT...DON'T USE IT...
                        • Luís Amaral
                          • Nov 2013
                          • 78
                          • Portugal
                          Re: Hp 650 BIOS
                          Allright, i can´t find the dumps on web, i only find on a russian website :|
                          • highpulse
                            i hate HP
                            • May 2013
                            • 1488
                            • portugal
                            Re: Hp 650
                            zer manel troca de bios chip :P , e relflasha , ja te safo a EC , ou queres a main ?
                            resuming what i sayed in portuguese . for it change the bios rom chip , and to reflash it , i will give him the dump , and share it of course
                            • highpulse
                              i hate HP
                              • May 2013
                              • 1488
                              • portugal
                              Re: Hp 650
                              and btw , the site bios is bigger because the bios file is not splited , so you got the EC and main together on the same file , i dont know YET how to cut it , but trying it with a few tips , cortesy of techmaster (robert) , he might help you , just give us your dumps , EC and main and also give the original found o the side , i think he will help you giving the new EC and MAin for y ou can try ,
                              • ala_borbe
                                aka Donald
                                • 1625
                                • Malta
                                Re: Hp 650
                                1. backup you old bios for DMI data
                                2. fix new given dump
                                3. program fixed dump
                                otherwise it will say that its some other model and serial num
                                dumped from
                                "HP Compaq CQ58-384SR
                                newton_cr&hr_hpc mv_mb_v1"
                                different model but same motherboard
                                ec+main
                                Im Back... sort of...
                                • ala_borbe
                                  aka Donald
                                  • 1625
                                  • Malta
                                  Re: Hp 650
                                  or if you are member you can download dumps here, uma and descrete... im not member
                                  http://www.elvikom.pl/schemat-hp-650...v1-t31357.html
                                  • Luís Amaral
                                    • Nov 2013
                                    • 78
                                    • Portugal
                                    Re: Hp 650
                                    Thank you, i´m going to try, i´m not a member of that !
                                    • Luís Amaral
                                      • Nov 2013
                                      • 78
                                      • Portugal
                                      Re: Hp 650
                                      Same symptom again :| maybe the problem is not the bios :|
                                      • dj_ricoh
                                        • 2073
                                        • uk
                                        Re: Hp 650
                                        video or no video dedicated? that`s the Q.
                                        did you do a reflow?
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • alphabetty
                                          novice user attempting first BIOS write on ASUS laptop
                                          by alphabetty
                                          Hello first post!
                                          Ok so after an (ASUSTek) optional Windows update, my old ASUS E403NA laptop rebooted and froze in the BIOS menu screen and was unresponsive so after about 30 mins I powered off and back on again. Now i just get a power LED and a black screen, I have tried all the basic suggestions and all the suggestions on the ASUS site, spoke to ASUS support who said I will need to pay for an RMA.
                                          The laptop is worth €50 so I won't be doing the RMA at god knows what price.
                                          So I have seen some videos where people have reprogrammed the BIOS...
                                          03-07-2024, 08:31 AM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
