Huawei NbDE-WDH9 (Board: DA0H99TB8E0 REV E HF)
This topic has been answered.
  • s.izadbakhsh
    • Jun 2026
    • 23
    • Turkiyeh
    I need a working BIOS dump for a Huawei laptop. The device powers on but has no display.
    Symptoms: The laptop turns on, and the keyboard is responsive (I can toggle the Caps Lock/backlight lights on and off), but there is absolutely no image on the screen. It looks like a corrupted BIOS issue.
    Device Details:
    • Model: Huawei NbDE-WDH9
    • Board Model: H98D DAH98DMB8B0 REV B HF
    • BIOS Chip: MX25L25673G @ WSON8 (8x6)
    • CMIIT ID: 2020AP10393
    • Serial Number (S/N): NQNPM23404000234
    I have already desoldered the chip and backed up the original corrupted dump.
    Thank you!
  • Answer selected by s.izadbakhsh at 07-09-2026, 07:58 AM.
    SMDFlea
    • 24945
    Originally posted by s.izadbakhsh
    Thanks for the file.
    Unfortunately, it didn't work. After flashing it, the laptop is completely dead now. It doesn't power on at all.
    I really appreciate your help!
    try this bios.
    • s.izadbakhsh
      • Jun 2026
      • 23
      • Turkiyeh
      Any Update?
      • shiyab
        • Sep 2023
        • 3644
        • india
        Device Details:
        Thank you!
        hi try
        • s.izadbakhsh
          • Jun 2026
          • 23
          • Turkiyeh
          Originally posted by shiyab
          hi try
            • 24945
            try this bios.
            • s.izadbakhsh
              • Jun 2026
              • 23
              • Turkiyeh
              Originally posted by SMDFlea
              try this bios.
              Thank you so much! The BIOS worked and the laptop finally turns on now.
              However, there is a new issue: I only get a display on an external monitor via HDMI. The laptop's internal screen remains completely black and doesn't light up at all.
              Could this display issue be related to the BIOS config (like EDID or display profiles)? Is there any way to fix this in the dump?
              Thanks again for your support!
                • 24945
                When it`s working via HDMI and not internal the fault is usually a blown fuse on the motherboard screen connection circuit , caused by removing the screen cable with the battery attached or adapter plugged in
                • s.izadbakhsh
                  • Jun 2026
                  • 23
                  • Turkiyeh
                  That makes a lot of sense, and it's highly possible that a fuse blew during the hardware troubleshooting.
                  Do you happen to have the Schematic or Boardview for this motherboard (DAH98DMB8B0 REV B)?
                  I want to check the screen connector area and locate the backlight fuse to test and replace it.
                  Thank you!
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
                • hartleyhare5
                  Samsung QE65Q9FN — BN44-00944A (65A board) MOSFET failure (relay clicking on one connect) — advice before power-up
                  by hartleyhare5
                  Post body:
                  I'm working on my Samsung QE65Q9FN (65" Q9FN QLED, European model) with relay clicking and no picture. The power supply board in the display itself is the BN44-00944A, known on the board itself as the 65A board (silk-screened designation). There is also a second board, the 65B, which looks identical but is only partly populated for the LED power.
                  Symptom: Continuous relay clicking on the one connect — TV will not start up, no picture. However the standby LED is on constantly — so the standby supply rail appears to be alive and the...
                  03-26-2026, 03:47 AM
                • Alfonso5
                  HELP IDENTIFY BURNT COMPONENT - HONOR MAGICBOOK X14 - BOARD DA0H99TB8E0
                  by Alfonso5
                  I’m working on a Honor MagicBook X 14 (Model: NBR-WAH9) that doesn't power on. I found a catastrophically burnt 8-pin IC near the touchpad connector (CN14 TP).
                  Motherboard Model:DA0H99TB8E0 (REV: E)
                  Problem: The component is so badly burnt that the markings are illegible. It is located right next to the ITE chip and the TP connector.
                  Request: Could someone please share the Schematic or Boardview for this board? Or if anyone has this board on their bench, could you please identify the markings (silk screen or chip ID) for this 8-pin IC?
                  I have attached...
                  04-27-2026, 08:07 AM
                • howardc64
                  by howardc64
                  07-24-2025, 05:17 PM
