Monster Abra A5 V19.3 - Tongfang GM5AGFO MB V1.1 - BIOS Dump Clean ME Request
  • s.izadbakhsh
    • Jun 2026
    • 19
    • Turkiyeh
    I need a working BIOS dump for a Monster Abra A5 V19.3 laptop.
    Here are the motherboard details:
    • Model: Tongfang GM5AGFO MB V1.1
    • CPU: Intel 12th Gen (Alder Lake)
    The laptop is currently in a boot loop (turns on and off immediately). I have desoldered the SPI Flash IC (GigaDevice GD25R256DYIG) and read the original 32MB dump.
    Note: I have already tried testing another BIOS dump found online, but the laptop behaves exactly the same (on/off boot loop) with both the original dump and the other file.
    Could someone please provide a working, verified Clear ME BIOS dump for this motherboard, or help me clean the ME region of my original backup?
    I have attached my original backup dump below.
    Thank you in advance!
  • jaglion19
    GI5CNXA MB v1.0 monster Abra A5 V13.3 HM370 CHANGE
    by jaglion19
    GI5CNXA MB v1.0 monster Abra A5 V13.3 SR40B HM370
    Good luck to everyone, my problem is as follows. I have a la-f841p rev 1a motherboard, which occasionally gives a blue screen due to the processor running the motherboard. I installed the southern chipset of this motherboard into the short-circuited device with Monster Abra A5 v13.3 GI5CNXA MB v1.0. When I trigger the monster device, it goes up to 230mah and turns it off again. I have tried many of these devices before, but I did not get any results. They definitely want a brand new chipset. Other models do not have this problem,...
    04-10-2025, 06:59 AM
  • bilen
    Monster abra a5 v15.8 bios dump
    by bilen
    Motherboard code : GK5MP5X VER 1.1
    There is a password in the old bios...
    02-01-2024, 07:29 AM
  • BigPete
    Panasonic LED TV Dead after EMMC dump
    by BigPete
    I recently took a dump of the 4GB EMMC dump of a new and working Panasonic main board and now the TV won't turn on.
    The dump was successful and the program finished without errors.
    I used a XGecu T48 to do the dump.
    I actually had a few issues getting it to go and I might write up something as a bit of a guide as I couldn't find much in English to go from.
    One thing I did do was connect a 1kohm resistor from the 1.2v line to the RSTN pin as per the instructions, could this have caused issues?
    I also shorted out the crystal of the adjoining ECU together and at one...
    03-15-2026, 03:08 AM
  • s_specialist
    Monster Abra A5 V16.7 SRKMA burned
    by s_specialist
    The south bridge (SRKMA) on my Monster Abra A5 V16.7 was burnt, causing a 1.8V short circuit to the chip. I installed a chip I bought from Aliexpress, assuming it was brand new, and the 1.8V output improved, but when I pressed the power button, it drew 0.03A and didn't start. I can measure 3.3V, 1.8V, and 1.05V on the chip. The BIOS has 3.3V on pins 1, 2, 3, and 8. When I pressed the power button, it drops to 3.3V. I get EC_RSMRST voltage from the IT5570E, but I don't have SLP_S4 and SLP-S5 voltages. I've written the bios files I could find, but I can't find anything. Is the integrated circuit...
    11-01-2025, 03:44 AM
  • mhd bero
    Monster Abra A7 V13.1 DIS GPU to UMA
    by mhd bero
    HELLO EVERYONE
    MONSTER ABRA A7 V13.1 HAS PROBLEM WITH NVIDIA GPU I DO REMOVE THE CHIP AND NVVDD COIL IT IS WORKING WITH INTEL GPU BUT SHUTTING DOWN AFTER ONE MINUTE CAN WE DISABLE DIS GPU FROM BIOS?
    THE MOTHERBOARD CODE 6-71-NK5K0-D02A NH50HKMB-0C
    01-20-2025, 09:53 AM
