Lenovo NM-D031 board, no video, shuts down after 25s despite stable power rails, need bios rebuild
  • DavidChunco
    • Mar 2024
    • 12
    • México
    Hi, I have this machine on the work bench (Lenovo IdeaPad/NM-D031/GS454/GS554/GV450/GV550 board, no DGPU).
    I’m trying to diagnose a power-on issue and I would appreciate some guidance or a clean BIOS rebuild.
    • Board powers on correctly
    • All power rails remain stable
    • No video is ever produced
    • System always shuts down after ~20-25 seconds (very consistent timing) and requires full power cycle to restart.
    • BIOS was previously reflashed with a known-good image and cleaned ME region (when reflashing with clean ME region it power cycles several times but then shuts down and returns to the same behaviour), i am not 100% sure if this bios image is compatible or suitable as this board has many variations.
    • Without SPI BIOS installed, the board does not even light LEDs or start power-up sequence
    • ADPIN / VIN: stable ~20.2V
    • 3.3V_ALW and 5V_ALW are present and stable
    • 3VALW_PCH and 1.8V_PCH are present and stable
    • SYS_RESET# stays at 3.3V stable
    • PCH_PWROK is stable
    • SLP_S3# remains high
    • All standby rails behave normally
    • System draws progressive current (~0.65A first seconds → ~0.9A → finally 0.350A briefly before shutdown)
    • CPU warms up during this time.
    • VCCIO is stable (~0.9V)
    • Multiple RAM sodimm modules tested with no change
    • Onboard RAM disabled via BIOS (same symptom when sodimm slot is populated, without any ram board stays on indefinitely with fixed power draw)
    • LCD_VDD is present (3.3V)
    • Panel power rail is present (~19–20V)
    • No backlight activity
    • No video output (internal or external HDMI, even with internal panel disconnected)
    I attach original BIOS dump (before any modifications).
    Firmware chip is Gigadevice GD25B127DSIG
    ideapad 3-15IIL05 Laptop - Type 81WE
    Serial number: PF315B10
    Model: 81WE01L7LM
    Any ideas would be appreciated.
  • Sparo
    Quicksilver
    • Jan 2022
    • 4543
    • M\A
    • Anime, Edge Computing, Football, Snooker
    Hi You have to post the Serial Number with every single request (As per the Forum rules)
    > RULES UPDATE for BIOS requests/offers *AVOID BANNING, READ BEFORE POSTING* - Badcaps
    Enjoying our forum? Subscribe to unlock extra perks!
    >> Upgrade here <<
    • DavidChunco
      • Mar 2024
      • 12
      • México
      Sadly there is no serial number or information visible on the bottom cover, however I found that if I scan the QR code on a sticker near the touchpad, loads a support webpage with the following info:
      Model: 81WE01L7LM
      • Processor
        1x 10th Generation Intel® Core™ i5-1035G1 Processor (Core™ i5-1035G1)
      • Memory
        1x 4GB DDR4-2667
        1x 4GB DDR4 2667
      • Operating System
        Windows 10 Home Single Language 64 (SP: Spanish)
      • Storage
        1x 256GB PCIe NVMe
        1x 1TB 2.5” 5400RPM
      • Wireless
        1x Bluetooth® 5.0; Intel® Wireless-AC 9560 2x2 AC
      • Ports
        1x Combo 3.5mm Stereo Headphone Output; SD Card Reader; HDMI; 1 USB 2.0; 2 USB 3.0
      • Camera
        1x 0.3MP with Dual Array Microphone
      • Graphics
        1x Intel UHD Graphics
      • Display
        15.6” FHD
      • Included Warranty
        1x Courier Carry-in
      • End of Service
        2026-04-02
      • Sparo
        Quicksilver
        • Jan 2022
        • 4543
        • M\A
        Model: 81WE01L7LM
        Use this BIOS file and transfer the DMI and Windows product key from the old BIOS to the new one at the mentioned offsets
        Copy the range from 622000 to 623FFF from your original backup and paste it into this one > https://www.badcaps.net/forum/troubl...28#post3865928
        >> Upgrade here <<
        • DavidChunco
          • Mar 2024
          • 12
          • México
          Just flashed your file with DMI data transferred from my original backup, but same behaviour, black screen and shuts down after 20-25 seconds
          • Sparo
            Quicksilver
            • Jan 2022
            • 4543
            • M\A
            You can also try flashing the EC from the same post I linked earlier
            Or try flashing an older BIOS version (EMCN40W) > https://www.badcaps.net/forum/troubl...60#post1478760
            >> Upgrade here <<
            • TechgeekSVK
              Msi Claw A1M From dead to life and i am at end
              by TechgeekSVK
              I’m troubleshooting an MSI Claw motherboard with a very strange power instability issue and I’m running out of ideas. Maybe someone experienced with handhelds / laptop VRM can point me in the right direction. History
              Originally the board was completely dead.
              I found:
              • Bad USB-C PD controller
              • Bad PU8 High Efficiency Input Synchronous Step Down Regulator
              • One previously reworked coil/inductor area
              After replacing the PD controller and PU8:
              • 20V negotiation returned
              • 3.3V and 5V rails are present and stable
              • Console now boots
              05-20-2026, 05:56 AM
            • luispisco
              ASUS Vivobook 16X K3605VV (DAZJ2SMBAF0 REV:F) - No Display / Need ME Clean or Rebuild
              by luispisco
              I'm working on an ASUS Vivobook 16X that turns on but gives no display (no POST, no Caps Lock light). I suspect a corrupted BIOS or ME Region and would really appreciate your help to rebuild my original dump.
              Here are the details:
              Laptop Model: ASUS Vivobook 16X K3605VV
              Motherboard Model: DAZJ2SMBAF0 REV:F
              Serial Number: S2N0CX01702606A
              BIOS Chip: GigaDevice 25R256EY1G (32MB, 1.8V)
              Symptoms & Troubleshooting Done:
              The laptop turns on via the keyboard power button.
              The CPU gets warm and the...
              04-13-2026, 06:46 PM
            • Elementallion
              PS3 CECH-2001B (DYN-001) shuts down after Vcore rise – VRM debug, no short found
              by Elementallion
              I’m troubleshooting a PlayStation 3 Slim CECH-2001B, motherboard DYN-001, and I’m stuck at a fairly deep VRM-level issue.
              I’ll try to provide as much structured information as possible.
              🔧 Initial problem
              Console behavior:
              • Press power → green light for ~1–3 seconds
              • Then shutdown with beep and blinking red
              • Fan barely starts spinning
              This looks like a typical early power fault / YLOD-type shutdown, but I’m debugging at board level.
              🔍 Measurements and observations
              🔌 Power rails
              • 12V rail: stable, no drop during
              03-23-2026, 09:32 PM
            • skwarszczow
              Macbook Pro A2141 020-01700-A GPU Artifacts then no S5 rails
              by skwarszczow
              This is my first post on the forum
              I recently purchased a MacBook A2141 from a colleague at work, which had issues with the dedicated GPU. The system occasionally displayed artifacts on the screen and sometimes experienced kernel panics related to the GPU. Interestingly, applying pressure to the VRAM module would temporarily resolve the artifact issues, which made me optimistic about the ease of repair.
              Board: 020-01700, Config: Intel i7, 512GB SSD, 16GB Ram.
              Before completing the purchase, we decided to erase...
              03-23-2025, 06:04 PM
            • SarcasticOP
              General question about MacBook power rails for repair.
              by SarcasticOP
              I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
              • PPBUS_G3H (12.6V-12.8V)
                • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
              • PP3V42_G3H (3.42V)
                • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
              • PPVRTC_G3H (3.3V)
                • This
              12-12-2024, 05:50 PM
